Question about HP Single Yellow Refill Bottle for HP 51641A Inkjet Cartridges Printer
How to i'm looking for directions for reflling the cartridges in the hp c5100....does the colored ink you sell work in this 02 series
  • 232 Answers
I think those cartridges can't be refilled because of the chip they have on them. You can buy compatible ones that can later be refilled. Check in a refill shop.
Posted on Apr 12, 2010
How to make pictures sharper
Regarding your recent inquiry about the HP 02 cartridge print quality/missing color issue in your HP Photosmart C5180 printer, let's first make sure that the printer is firing all 6 cartridges correctly. Based on your problem description, it sounds like there either an air bubble in one of the printer ink lines or a portion of the PRINTHEAD* could be dry, so you should first perform a "Clean PrintHead" procedure from your printer's 'TOOLS' button on the control panel.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidentally ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the "Clean Printhead" procedure 2-3 times. Depending on your printer model, refer to the applicable video procedure:
http://inkjet411.com/?page_id=2377(Printers without 1-9 keypad)
http://inkjet411.com/?page_id=2391(Printers with 1-9 keypad)
However, if you have already attempted to clean the printhead and one or more colors are missing, then it is suggested to run the 'Tap 43' printer diagnostic test to ensure the built-in PRINTHEAD (inside the printer) is functioning properly*
http://www.youtube.com/watch?v=X8Hr5YgSqT4(Printers without 1-9 keypad)
http://www.youtube.com/watch?v=kEfCWJMpfZ8(Printers with 1-9 keypad)
Refer to the HP Printer Diagnostic's document (PDF file) at the following link for advanced diagnostic tests for your printer model: http://inkjet411.com/?page_id=1813
To completely verify the ink lines are clear and working correctly, print the "INK RECOVERY TEST PRINT" from our Test Prints page (intense color drop pattern): http://inkjet411.com/?page_id=146
As an option (to help conserve ink), you could just run the Self-Test Report (under 'PRINT REPORT' menu), this will verify nozzle performance and that each color is firing a solid band of color (i.e. you should not see any bands or missing lines in the pattern). This is also a good test to help isolate which color (or portion of the electronic PRINTHEAD*) may be causing the issue.
If a problem persists (poor print quality/nozzle misfiring/missing colors, etc.), then we suggest that you thoroughly review the steps outlined on our HP 02 support pages, including printer cleaning and service station cleaning. It is suggested you refer to printer manufacturer instructions first as the Inkjet411 procedures are provided for informational purposes only. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors.
http://inkjet411.com/?page_id=35 (HP 02 main page)
If this does not remedy the problem, then you may have a defective PRINTHEAD* in the printer (worst case scenario), unrelated to the refilled cartridges. As this printer writing system (found on 58 different HP printer models) is between 10 and 12 years old there is a very good chance that the PRINTHEAD has reached it's END OF LIFE.
*The HP 02 ink series printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 6 ink cartridges and then firing the ink droplets onto the paper) - the HP 02 PRINTHEAD typically has a maximum life of approximately 25,000 pages (~15,000 page average). Unfortunately, the permanent PRINTHEAD is not replaceable. http://inkjet411.com/?page_id=2054
CAUTION: Be advised, the use of HP 02 compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD damage due to incompatible ink formulations (i.e. contain Volatile Organic Compounds which are known to damage the built-in PRINTHEAD). We do NOT suggest using or refilling these types of ink cartridges.....refilling of HP 02 or HP 02XL original/genuine ink cartridges is only suggested!
HP 02/02XL Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=SGA692TUWTc
If you need to purchase a new HP 02 (or HP 02XL) ink cartridges, we suggest you try a USA remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating (free shipping for all orders above $20).
We trust this helps explain the issue your printer is currently experiencing. For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Aug 30, 2014 | HP Photosmart C5180 All-In-One InkJet...
What is an OEM cartridge?
OEM (pronounced as separate letters) is short for original equipment manufacturer
The Cartridges for the HP DeskJet 3740 InkJet Printer are:
HP 27 Black Original Ink Cartridge
HP 28 Tri-color Original Ink Cartridge
These can be purchased from your local store that sells HP Printers & ink or by going to HP.com and ordereing direct from the Manufacturer
May 01, 2014 | HP DeskJet 3740 InkJet Printer
How do you get the ink to work? I put in new ink and when I am printing a page, the page is blank.
If the ink cartridges is a refll, generic (not HP), a lot of HP printers will only use HP ink cartridges that is new , no refill's...Sorry I had the same problem...
Sep 19, 2011 | HP Deskjet D1341 InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have lost my ink level viewer. Hp Photosmart c5100 series. It used to show everytime I printed but now it is not there and I can't seem to recall it.
Did you install non-authentic HP cartridges? It doesn't like that and witholds information as punishment.
Try putting the following address into your web browser:
http://192.168.1.6/
this brings up my ink levels. However, I don't understand these things and you may need your own individual printer specific code.
May 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
We have long had an HP PSC 750. We don't print in color and a tech person at HP told us just to buy black cartridges and take out the old color cartridge & put it back in and set the printing prefs for...
You must replace the color ink cartidge because the inking system uses both cartridges even on just black prints.
Sad, but true. This is how HP makes their money. Selling ink, not printers.
I'm a good ol' US of A boy.
Jan 22, 2009 | HP PSC 750 All-In-One InkJet Printer
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
41 people viewed this question
Ben Johnson
