Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
How do you turn off the water dispenser in 59562990?
We want to disable the water the dispenser for our fridge, mostly because our two yr old is making a huge mess. Any ideas?? It would be nice to keep the ice dispenser working, but if both have to be disabled, then so be it!!
  • rcsmellis Jul 23, 2008
    Thank you! My husband did exactly what you suggested. Worked like a charm! Again, thank you.
    Scholar:
  • 50 Answers
If it has water and ice, the inlet valve will have at least 2 coils. You can pull the fridge out, take off the bottom panel and pull the 2 wire connector off just the water coil. Depending on the fridge, there may be multiple choices, look for the tube that does not run up the back of the fridge and disconnect the wires going to it. Then try the water dispenser, if you don't have water you should be ok, if you still do, replace the wires you've taken off and try another connector.
Posted on Jul 22, 2008
Why is aSide by side fridge leaking brown liquid from below ice maker?
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
We have a side by side Whirlpool frig/freezer, only a yr old, model #ED2KHAXVQ01. It has the ice dispenser & water dispenser on freezer door. The water and icemaker are not working and we checked for...
I can only think of a couple of things to check, 1. if there is a small screen on the end of the water line that delivers water to the refrigerator, it may be plugged, and 2. maybe the filter in the refredgerator it self is plugged.
Nov 06, 2017 | Refrigerators
Water underneath the freezer section
Please check for the water passage beneath the freezer. There will be a small pipe and there is a possibility that that pipe path is blocked with ice or dirt.
Mar 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Regulating Temps on Whirlpool Side by Side
well i think you know what this is!!!!
you moved it and it got upset about it?
but some freezers need to be dead upright
or,,,its the darn thermostat's there playing you up like mad if you cant control them there on there way out
best bet is have new ones fitted or just dump it all together,,after all think of how much that floor is worth? and how much ice cream do you need????
ps,,,i use a hammer drill to get my ice cream out the tub?? have you ever tryed "fried ice cream" its realy
"""""yucky"""""??? (sorry im mad you see)
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Occasional small puddle of water on floor in front of unit on door handle side. it is a 25 yr. old Amana no ice maker or water dispenser in door
there is a drain pan for condensation under the fridge. over this many years the is dust and lint that will fill the pan and displace the water on your floor. while your under there clean the coils. this will help get every year possible from your fridge
Jul 27, 2009 | Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
126 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
