Question about Lands Phones
Phone line splitters
I have 2 3 way phone line splitters and only line 1 will get me a dial tone on both splitters
    Scholar:
  • 108 Answers
Your jack probably only has one line installed on it, therefore you only get one line. Have you checked to see if the jack has more than one line installed?
Posted on Jul 28, 2008
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
No dial tone
you have a problem with the drivers that you've installed.
Apr 11, 2008 | Canon PIXMA MX700 All-In-One InkJet...
No dial tone when pressing hook fax is returned
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 06, 2010 | Brother Multi-Function Center MFC-240C...
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
Need two phones connected to the one jack in our office.
Have you purchased an incorrect splitter. You may have one for 2 lines rather than one used to split one line. Radio Shack has the proper one.
Aug 19, 2009 | Lands Phones
No dial tone with 3730
No dial tone means the terminal is not getting a signal from the phone line.
Troubleshooting:
1) Make sure it is not on a splitter most of time the splitter goes bad.
2) Make sure the phone cord used is a 2 pin cord.
3) Make sure if you have DSL from your phone company plug it in a DSL filter but make sure
you drop the baud rate the terminal uses.
Hit the more key (2nd purple key from left usually the tip key) until you see other setup.
Enter Password Default 1 Alpha Alpha 66831 Alpha key is the little black button above
the number 2.
Then hit the more key again until you see COMMS choose that and hit next until you see
Baud rate. Hit Edit and then NEXT until you get 300 baud when that shows under new hit
select or enter. Choose F4 exit save changes and then the red X key until you are back at
main sales screen Run a test sale.
If still same problem Repeat steps and change baud rate until one works. Usually 300 will
work for DSL lines.
Call me if you need assistance.
www.greenlightpayments.com EXT 105
Jul 02, 2009 | VeriFone Omni 3700
2 line phone and hp 3309a all inone.
if you having problem with a splitter, then the porblem is at phone comany end, not the fax machine or your phone, I would call the phone company to check out their line.
May 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Mar 20, 2009 | Uniden TRU9466 Cordless Phone
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
No dial tone
Do you ahve the Cable connected to the LINE socket and NOT the EXT Socket? M
Aug 18, 2007 | Brother MFC 420CN All-In-One InkJet...
Lands Phones Logo
104 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
