Question about Philips Televison & Video
Tv do not turn on, just black and makes a squeaking sound
I called a technician, thank you, Barbara
Posted on Jul 23, 2008
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Sep 05, 2012 | Canon PC-921 Black and White Copier
Panasonic PT-47WX33G doesn't start up (no picture no sound). Power indicator blinks 5 times while I hear a repeating squeaking sound inside the TV (squeak squeak squeak squeak squeak). I replace...
If your set is blinking 5 times it is the HV power supply.
You most likely have a sorted Horizontal Output Trasistor. (HOT)
If you have any further questions please respond to this post.
Thanks
asnowman
Jan 22, 2011 | Panasonic Televison & Video
Samsung dlp shuts off at various intervals, new bulb, when you turn it on i can here a slight buzz,squeak type sound, makes me think ballast but then i read about the color wheel it does make the click but...
U have buzzing,squeaking.Some fading colors,black and white?Ur colors wheel is dead,it spinning off it axis.The Ballast is dead,u turn on the tv will making cliking noise,power shut down couples sec. after that.
Apr 30, 2010 | Televison & Video
Tv does not turn on and makes a squeaking noise only
Ur high voltage is dead.The FBT,the flyback tranformer is dead.The big black block of plastic with a red wire with a cap that hook to the CRT(tv tube).Take it to the shop to get an estemate and repair,beccause FBT it hard to find these day.Involved with high voltage and soldering.
Mar 17, 2010 | Televison & Video
Squeaking sound from shock absorbers
ball joints won't squeak like that; they make a popping noise when they're bad. it is very common for shocks to get water in them and start squeaking, and it's usually a horrible screeching squeak. The only way to get rid of the squeak is to change out the shocks. Hope this helped.
Nov 28, 2009 | 1997 Ford Expedition
My car makes a squeaking sound when turn my wheel
more than likely your power steering pump check it's level if it's low or really dark take it to have it looked at, if not then check your belt if it's getting streached it will slip when your turning the wheel and using pressure from the powersteering pump. hope this helps
Mar 04, 2009 | 2001 Ford Focus
My phillips CRT TV won't turn on - when I switch it on with the remote, the power light doesn't illuminate and a strange squeaking noise comes from within - it sounds like a bird chick squeaking at around...
Sounds like the HV generator needs replacing. You can get a replacement at the following link. If your not sure which one your model uses, leave them a email with the model number of your set.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Televison & Video
High pitched squeaking sound
THIS PROBLEM IS CAUSED BY THE LINE LINEARITY COIL VIBRATING AT LINE FREQUENCY [15.625KHZ] WHICH IS AUDIABLE TO THE HUMAN EAR AS A SQUEEL . THE CURE IS TO DEPOSIT HOT GLUE AROUND ALL COILS SITUATED AROUND THE LINE OUTPUT TRANSFORMER
Mar 06, 2007 | Beko 324250WN 28" TV
Televison & Video Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
