Question about Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator
Only crushed ice from ice dispenser
My Fridigidaire Professional side by side has recently started dispensing crushed ice only no matter id you select cubes or crushed. Any idea on what is wrong and how I can fix it?
Switch is frozen. Defrost freezer and it starts working again.
Posted on Jul 23, 2008
Ice maker will only crush, won't let you get cubes
The dispenser door is staying open and allowing warm moist air back inside the freezer. This are is causing the frost to build up in your ice bucket.
You will need to put your finger up into the dispenser and push it shut. The other option is to get the dispenser solenoid replaced.
Good luck.
Jul 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Model JCD2389GEW - ice/water dispenser does not work. Until recently, it did not do anything on any of the settings (water, cube and crushed ice) now it crushes ice on all three settings but the door does...
We have a Jenn Air side by side, model JCD2389GEW. The ice dispensers work, the water does not. This started after I replaced the filter. I've checked and nothing is locked out. When you press the actuator pad to dispense water, you can hear a noise similar to a small pump which I assume is a solenoid attempting to open. Any ideas?
Oct 02, 2009 | Jenn-Air Refrigerators
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE Monogram Icemaker will only dispense crushed ice
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Door ice dispensor will only dispense crushed ice
Pull out the ice drawer and close the door switch the crushed /cubed button put the ice drawer back in and switch the selector button again. You might have to repeat the process I had the problem this week and by jiggling everything around and running a good bit of ice thru it started working again. Good luck
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker will not dispense ice cubes only crushed ice
sounds like the circuitry on your Cubed Ice button has malfunctioned. Contact the manfacuturer for a solution.
in the meantime, u can grab the Cubed ice manually.
hope this helps!
Jun 16, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator Logo
101 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
