Question about Canon ImageClass D880 Copier
Prints blank pages
Changed toner cartridge & the problem remains. Will not print, just send a blank page thru. Even a report is blank, Help what am I not doing right
  • anounce474 Jul 22, 2008
    The exposure light comes on. The cartridge was changed with a cartridge from a working machine. The pages are completely blank. The report page is blank. What could it be?
  • Jim Keysor May 11, 2010
    Is the exposure lite coming on? Check the cartridge make sure it is installed all the way or even try a second cartridge. Usually no copy or lines on copy, etc come form the cartridge area in laser style machines.
    Sergeant:
  • 329 Answers
Sounds like a power supply problem most likely the DC power supply. This applies power to the cartridge to transfer the image to the drum and seperation. How old is machine, Is it possible to be under warranty?
Posted on Jul 23, 2008
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
Printer prints blank pages
This is almost certainly an issue with the toner cartridge. I would recommend running off 30 or so prints and contacting whoever the cartridge was purchased from if the toner doesn't pull through.
Nov 18, 2012 | Brother HL 2140 Laser Printer
When i send a test page from the printer p3005x it print blank page
Hello, Try a different cartridge if you have one (even a used one). Does it print anything? If "Yes" then the printer is most likely OK and the fault lies with the Toner Cartridge. Checks - 1) the Drum Flap operation, does it move freely. 2) Check the electrical contacts, look for bent pins or toner accumulation on the contacts. Replace the Toner Cartridge with a new one. If "NO" the Printer still prints blank with multiple cartridges, the a printer may need servicing, check the left side of the inside of the printer, this is where the toner cartrisge contacts are located, check for bent pins or paper obstructing the pins. USA Service Centre Support http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Jan 15, 2011 | Office Equipment & Supplies
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
Black Prints
The toner might be bad, because the old cartridge is working fine.
Jul 31, 2009 | Xerox DocuPrint P12 Laser Printer
Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Jan 08, 2009 | Canon LBP 800 Laser Printer
Blank pages
Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
Dec 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Blank papers
Try again the old toner cartridge if you still have it. Even though the print quality might be bad, see if there is a printout. If the page is not blank like the others, that is an indication that the new cartridge is defective and has to be replaced.
Sep 05, 2007 | HP LaserJet 2420 Printer
Prints blank page even when used by itself
weird, this problem accours almost only in lazerjets. anyway, you can try the following: 1. Unplug data cable. 2. plug power cord directly to socket (as opposed to extension) . 3. remove memory card. 4. changed toner cartridge. also, the info in the following page may assist you: http://support.microsoft.com/kb/q189764/
Mar 24, 2006 | Epson Stylus CX6400 All-In-One InkJet...
Canon ImageClass D880 Copier Logo
124 people viewed this question
old marine
old marine
