2000 Chevrolet Impala Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Antenna Trigger: White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
First thing you will need to do is to buy a wire adapter for your specific make & year of car. This interfaces the stock wiring plug allowing you to connect the wires from the headunit to the wires of the plug.
Here is a color coding explanation for the wires on your Alpine Deck:
P o w e r
Memory (+12v Constant)
Yellow
Ignition (+12v Switched)
Red
Ground (-)
Black
Dimmer
Pink/White (Alpine only)
Power Antenna
Blue
Amplifier Turn-on
Blue/White
Phone Mute
Light Blue (Sony only)
S p e a k e r s
Right Front (+)
Gray
Right Front (-)
Gray/Black
Left Front (+)
White
Left Front (-)
White/Black
Right Rear (+)
Violet
Right Rear (-)
Violet/Black
Left Rear (+)
Green
Left Rear (-)
Green/Black
1995-97 Nissan Maxima Stereo Wiring
Constant 12V+
Pink/Blue
Switched 12V+
Blue/Black
Ground
Vehicle Chassis
Illumination
Red/Blue
Dimmer
Red/Orange
Antenna Trigger
Black/Red
Antenna
Right Rear
Front Speakers
6 1/2" Doors
Left Front (+)
Blue/White
Left Front (-)
Blue/Yellow
Right Front (+)
Brown
Right Front (-)
Brown/White
Rear Speakers
6 1/2" Rear Deck
Left Rear (+)
Red
Left Rear (-)
Green
Right Rear (+)
Blue
Right Rear (-)
Pink
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
fun fun fun. 1990 Toyota 4Runner Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
You should really invest in a $15 wire harness so you do not have to cut the factory plug. Instructions will be in the package - but in the event you dont have a factory plug due to theft - here is the vehicle's wiring color codes...
Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger: Blue
Left Front Speaker Positive Wire (+): Light Blue/White
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): Dark Green
Right Front Speaker Negative Wire (-): White/Light Green
Left Rear Speaker Positive Wire (+): Tan/Yellow
Left Rear Speaker Negative Wire (-): Gray/Light Blue
Right Rear Speaker Positive Wire (+): Brown/Pink
Right Rear Speaker Negative Wire (-): Orange/Red
Left Front Speaker(+)
ORANGE/L GREEN
; Size:
Left Front Speaker(-)
L BLUE/WHITE
; Size:
Right Front Speaker(+)
WHITE/L GREEN
; Size:
Right Front Speaker(-)
D GREEN/ORANGE
; Size:
Left Rear Speaker(+)
PINK/L GREEN
; Size:
Left Rear Speaker(-)
TAN/YELLOW
; Size:
Right Rear Speaker(+)
PINK/L BLUE
; Size:
Right Rear Speaker(-)
BROWN/PINK
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink Car Radio Switched 12v+ Wire: Blue Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Red/Blue Car Stereo Dimmer Wire: Red/Yellow Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Blue Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Black Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Light Green Left Rear Speaker Negative Wire (-): Violet Right Rear Speaker Positive Wire (+): Blue Right Rear Speaker Negative Wire (-): Pink
hi, first you are better off to purchase a conversion plug from a stereo outlet (so that you arn't cutting the standard plug off)
the colours should be
orange/pink = L/F Speaker
orange/black = L/F Speaker
grey/green = R/F speaker
grey/black = R/F speaker
pink/black = L/R speaker
pink/green = L/R speaker
blue/black = R/R speaker
blue/red= R/R speaker
blue/white = switched wire
black = earth
green/yellow = hot wire
these are ef but should be the same
happy motoring
