Sharp R-1874 850 Watts Convection / Microwave Oven
Problem for Sharp R-1874 850 Watts Convection / Microwave Oven
Sharp r-1874 - 59 sec
By adawntlw on Jul 22, 2008
how do i get the front off, its a built-in
Same Problem
Nov 30, 2008
-   To replace the damper motor in R-1874 I need to remove this over-range unit from its mounting bracket. Simply reversing the intsallation instruction does not work. When the mounting bolts (accessed through the grease filter port) are loosened and disengaged, the unit is free to rock forward about one inch, then it hangs up on on something on the wall bracket. There are no cabinet screws in this installation, and the power cord is not the interference. This is an RV installation in a 2004 Carriage CW374. What's up with this?-   Guest
Best Solution
posted on Jul 23, 2008
Very Helpful)
MicrowaveSvc
Rank: Guru  Sharp Kitchen Appliances  Expert
Rating: 89%, 5019 votes
We have the service manual, and have uploaded it to our site here. It is only a supplemental type, so it does not show disassembly, but it has helpful info and part numbers
We have a handy disassembly video at http://www.microwavedisplay.com
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Comments:
Nov 14, 2008
- For parts, you can call Tritronics toll-free at 866-779-5835.
Jan 02, 2009
UPDATE: Tritronics is now
Encompass and you can order from them here or by calling 866-779-5835 toll-free.
Jan 02, 2009
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sharp R-1874 850 Watts
Questions and Unsolved Problems for Sharp R-1874 850 Watts
Do you recommend Sharp R-1874 850 Watts Convection / Microwave Oven?
Answer
Answer
sharp R1874 works only intermitently If you put 2 minutes it only works for 1 minute 1 sec.
Answer
Suddenly, after 3 yrs. use, turntable not operable. Driving-stud does not turn.
Answer
The panel display on my Sharp microwave R874 Jet Convection and Double Grill does not work since we... (More)
Answer
Sharp microwave R-1874. Does not heat Timer, lights, cooling fan work. Turn table does not turn ,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave... Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
