Question about Panasonic Office Equipment & Supplies
Fax/phone displays communication error code43
    Sergeant:
  • 284 Answers
Error code 43 means low toner or defective toner
Posted on Oct 01, 2008
Sending fax displays comm.error
There are many things that can interfere with proper sending of faxes. Has anything changed in your office recently? Phones changed? Did you recently get DSL service from your phone provider? If so, you probably need a DSL filter on the line going to your fax machine. Try faxing to different faxes to make sure that it is not the person you are sending to that has the problem. If you are using Voice Over IP or VOIP phone, good luck, as older fax modems do not always play nice and you will likley need to speak with your VOIP provider to ensure they have their lines configured. If nothing has changed in your office then perhaps your modem has just failed, it does happen. A new cord between the jack and the machine is a a cheap test as well. If you have a telephone, unplug the fax and plug in the phone and see if you can make a call.
Sep 04, 2014 | HP LaserJet 2840 All-In-One Printer
Communication error 43 message every time and with every number.Panasonic fax kx-fhd332
COMMUNICATION ERROR (Code: 43, 44) means that "A line problem occurred". There might be a problem with the phone jack where your fax machine is connected to. Try to connect the telephone line cord to a different jack and try again.
Mar 21, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
When I send a fax, I get error code 322. I can't receive faxes either.
The error depends on the fax model that you are using. Error 322 on Canon Fax and other machine may significate that the Fuser is not heating (Usually Bad Fuser Module).
A different thing is Comm error 322 on computer, that means that there is no communication, and can be caused by bad phone cable, software problems and hardware problems.
In that case ensure that you are using a fax cable with two poles. If the problem started recently do a system restore to a date before the problem started.
If you get the 322 on display, even when computer is not connected, you usually need to replace the fuser unit.
Regards.
Mar 06, 2010 | Computers & Internet
Kyocera KM-3050 - Faxing error code
Try calling that number from a regular phone and listen for fax tones...it may not be a fax number.
Oct 15, 2009 | Kyocera Office Equipment & Supplies
I am trying to send a Fax but keep getting a communications error
Vonage is a DIGITAL phone service. ALL fax machines are analog devices. You need a plain old telephone line.
Jul 22, 2009 | HP LaserJet 3050 Printer
Unable to fax to a certain number
She may have a digital phone line, such as DSL...Vonage...etc.
Sep 11, 2008 | Brother IntelliFax-2820 Laser Fax
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
OKI 5550mfp Fax Problems
error 209 - Media Table Download Failure MediaTable Download to PU failed. Reboot.
CU firmware detected an anomaly in behavior in PU (including a violation of communication protocol between CU and PU).
are you suing unusual sized paper?
Feb 19, 2008 | OKI C5550N Multifunction Printer - Color...
705 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
