Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Screen appears curved on top and bottom
My Phillips 55PW9363 Projection TV literally broke overnight. It was fine last night but wasn't when we turned it on this morning. The screen had a double image, red and blue so it was definitly out of alignment everywhere except right in the center of the screen. I went into the Multipoint Convergence and sure enough, the crosses in those areas were out of alignment. Many of them were bent so I could not adjust them perfectly. So I adjusted them as best as possible. Now the double image is gone but the screen is curved on the top and bottom. I'm sure something broke or went out but I don't know what. Would you know what would cause this and what part(s) I would need to fix it?
Thanks for your help,
Laura
  • 1 more comment
  • Anonymous Aug 23, 2008
    I have the same problem.
  • hufford Sep 14, 2008
    I have the same problem as ellaura86. Was fine when I turned it off, but when I turned back on hours later, that's when it did the same thing as ellaura86. Any help would be appreciated. Thanks, Jhufford.
  • csbutcher769 Jan 23, 2009
    I have the same problem on my 60 in. television. please let me know if anyone knows how to fix this.
  • Philips Master
  • 3,459 Answers
One or more colors can't be adjusted when when using the convergence menu. Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Posted on Jan 30, 2009
Black screen
It is likely that you now have power supply trouble.
May 26, 2013 | Philips Televison & Video
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Our Phillips HD projection tv has lost a picture. It started by blacking out once in a while but now the picture is constantly rolling. The screen is distorted and it's impossible to even recognize what is...
Cloudy,distorted pictures.The tv have R,B,G CRT tubes gun coolant probblem.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced.
Sep 11, 2010 | Philips 55PW9363 55" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Picture curves in @ top and bottom and color convergence is off. was fine yesterday.
There are bad solder connections on the flyback transformer and there is a small fuse open. Pretty hard to do yourself but a professional can do this easily.
Apr 15, 2009 | RCA HD56W66 56" HDTV
Uneven projection at the top and bottom of the screen
Could be Pincushion or Geometry out of line. Need pic to be sure.
Mar 12, 2008 | Philips 55PW9363 55" Rear Projection...
Phillips 55PW9363
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | Philips 55PW9363 55" Rear Projection...
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Blue Spot in top center of screen
same problem, guy said i need a COLOR DRIVE!! $1000, trying to find cheaper
Jan 07, 2007 | Hitachi 60V500 60" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
175 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
