Dacor Preference SGM466 Gas Cooktop Logo
Posted on Feb 08, 2011
Igniters won't stop Dacor Preference SGM466 Gas Cooktop. Tried cleaning and want to remove the burners. What is the correct way to do so?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 18, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
419
Points
Problem is the insulation on the spark wires is dried and cracked. I bet you can hear the sparking coming from inside the unit, rather than where you see the spark, correct? The excess voltage is grounding inside, rather than thru the flame. I believe you pull the burners off and tap those brass rings with a screwdriver/hammer (or buy the correct tool). Then you can lift the entire top off.
Came into the kitchen this morning and one of the igniters was clicking away. Cleaned all the igniters. Still clicking away even with the gas off
This is usually caused by water spillage getting into one of the control switches directly below the knobs. It may have gotten in it the night before, but took awhile before causing the ignition system to activate. Let it dry out a day or so and it usually stops.
Vent does not rise to clean air
come again boss, i don't get what you mean?
I have a five burner stove top the ignitore just stopped working. What could be the problem
The ignnition switch will just stop working. Go to your local gas fitter and ask for a pietezzo switch, take yours along if you can, its easily accesable from underneath with a 10 or 12mm spanner.
Dacor cooktop igniters keep clicking even after the burner is on
there should be 2 d size batteries in the bottom ov the oven just replace them that should stop it i had the same problem
3helpful
2answers
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Gas Stove Top Burners
The burner are fixed only maintenace are to clean burner /clean holes and edge in order flow of gas good performance.At the back if you want make more good performance of your top burner clean the nozzle where the air and gas mix . Clean the nozzle w/fine niddle /sometime if will corrode with rust and dust to struck flow of gas.
Some Burners Will Not Ignite
probably a worn wire to the electrode or a cracked ignitor. you are faced with taking off the hobtop and looking - no easy solution. you should not do this unless you are confident and don't interupt the gas path
Top Dacor Cooktops Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
