Question about Lexmark X3470 All-In-One InkJet Printer
Cannot Install or Uninstall printer
I just recently tried to install Lexmark X3470 onto my computer. Somehow or another, it got uninstalled and I needed to put it back on the PC. I was in the process of installing it, but it froze up while putting in the Fax information. I tried to uninstall it with the uninstallation file, but it wouldn't run. What do I do?
Instalar lexmark x 3470
Posted on Jul 26, 2008
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
I am unable to uninstall my lexmark printer driver from my laptop... i was trying to install the new driver and it refused to over ride the previous installed driver and then i did a system restore and now...
Please try this. Run the install disk/web installer -> select Support -> select Uninstall. If Uninstall initializes, reboot your computer after the process finishes. Then reinstall using the new driver.
If the "Uninstall" option is not available, it would be best to contact Lexmark technical support for assistance.
NOTE: MAKE SURE TO USE THE PRINTER DRIVER COMPATIBLE WITH YOUR COMPUTER'S OPERATING SYSTEM.
Nov 11, 2010 | Lexmark X2550 All-In-One Printer
I can't uninstall lexmark 2500.
cleanup tool
ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/
run it when finished restart computer, go to add/remove program try uninstall again, select yes when it ask you if you'd like to remove it from add/remove.
regards
Jun 29, 2010 | Lexmark X3470 All-In-One InkJet Printer
My lexmark x3430 printer and my computer want comunicate my my computer is a dell with vista
If you have already tried turning off/on the printer, detaching and re-attaching the usb cable but still it didn't help, you might want to reinstall the printer driver. I recommend you detach the printer from your computer then uninstall the software. To uninstall, click on the Windows logo Start menu > Programs > Lexmark 3400 Series folder > Tools > Uninstall. Then restart pc. Also, check if your computer is running on 32-bit or 64-bit operating system by clicking on the Windows logo Start menu > right click on Computer > Properties. For the software, click on this link: http://bit.ly/dckTwb (for 32-bit) or this link: http://bit.ly/cIiFAH (for 64-bit). Download and install the software. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 27, 2010 | Lexmark X3470 All-In-One InkJet Printer
Old computer died. new computer has Windows 7. Can't get printer to install even though it says it is and status is good. Help!
Try the link "Upgrading to Windows 7?" from this Lexmark support page. This is also where you would download the software for your model and OS.
Lexmark X3470 Downloads
If attempting a reinstallation, uninstall the current printer driver first and follow the "Upgrading to Windows 7?" information.
Jan 08, 2010 | Lexmark X3470 All-In-One InkJet Printer
Is the Lexmark X3470 compatable with Windows Vista? I cant get it to scan onto my computer but it'll print fine.
Yes, according to the Lexmark website, your printer model is compatible with Windows Vista and even Windows 7. I would suggest that you uninstall the drivers for the printe/scanner and download the new drivers from their support website, then re-install the printer/scanner using those drivers.
You can find them here:
http://support.lexmark.com/index?locale=en&userlocale=EN_US&productCode=LEXMARK_X3470&page=product&segment=SUPPORT#1
I hope this solution helps you.
Aimeri
Dec 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Scanner won't work. Says I need to install OCR from CD.
never let a machine defeat you.
uninstall. REBOOT; reinstall; invoke the scan tools menu
select SETUP click FACTORY settings to invoke mfr defaults.
go to scan and OCR tabs and make sure you have checked all radio buttons and boxes so make all preferences.
click APPLY, OK and REBOOT. happy printing.
Mar 13, 2009 | Lexmark X3470 All-In-One InkJet Printer
Hi u need not install fax software for this machine..its a standalone fax machine..the fax software provided for fax is for computer faxing..
first find which operating system u have on ur computer..if its vista..try downloading drivers and then installing
Feb 11, 2009 | Lexmark X5495 All-in-One &USB...
Cannot connect my printer to my computer
This came right off of the lexmart site
Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Nov 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cd lost for installation lost installation cd and got a new computer, need to install somehow
Here are drivers for the printer - download them (click 'Get'), plug the printer in and then install the drivers.
Jun 10, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
108 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
