Question about HP (D9896-69007) Motherboard
Trouble startup Always get error 0502 hardisk not responding or ther is an error What can i do. It is a HP E Vector D9896 60009
  • 2 more comments
  • Henk Jansen Jul 27, 2008
    I tride it but dit not work.Windows wont start at oll New harddisk with W98 same problem hardisk not responding. W98 cd in diskstation startup working but than no harddisk present. Fdisk same problem no harddisk. What can I du ????
  • Henk Jansen Jul 28, 2008
    It is not going my harddrive is on master, cable set properly, but in bios i have only the main page so i can not set automatically scan for harddrives. I have fdisk on a cd while there is no diskdrive. After starting fdisk i get the message no fixed disk present ?????????
  • Henk Jansen Jul 29, 2008
    Ther is no vista on harddisk. I check for the jumper cannot find it only a swich to clear cmos. But i have dan it no succes problem the same
  • Henk Jansen Jul 30, 2008
    I am going to try this , report to you later wen i compleet this for now thank jou very much. I am now very bussy at this time.
  • 781 Answers
Checked the web seems this number relates to a printer problem try starting in safe mode f5 or f8 uninstall printer drivers and see if computer works
Posted on Jul 22, 2008
  • 2 more comments
  • David
    David Jul 27, 2008
    there are various things to try
    1) check cabling to hard disk the broad cable that goes in the back must have the stripe on it next to the 4 pin power plug
    2) the hard drive must be set for primary. At the back of the hard drive is a small section that has 6 or 8 pins in it either written on the hard drive is instructions where to set up for primary or by the pins themselves is three codes
    pr =primary
    sl = slave
    cs = cable select.
    3) go into the BIOS and set it to automatically detect hard drives
    Please let me know how it goes
  • David
    David Jul 28, 2008
    You may need to reset BIOS back to default settings
    if you can get into bios check which key to press for default or reset the bios this way
    On the M/board will be written somewhere reset bios or words to that effect it should be a small 2 pin connector with a jumper on 2 pin with computer off connect the jumper across both pins for 30 seconds then remove jumper fit back over 2 pin (not Lose) restart computer.
    One last thing Did you have the maker O/S installed vista if you did and are trying to install another operating system you must use a full version not an upgrade one as the vista has taken over some instruction in bios
  • David
    David Jul 28, 2008
    I meant vista has set you hard disk boot sector so its not recognized you must use full version of operating system to overcome this
  • David
    David Jul 29, 2008
    Did you have vista installed at some time B4 as I had this problem when I took vista off and went to install a upgrade version of XP I had to use a full version to overcome vista writing to boot sector of hard drive
    Download (Hirens Boot Disk) or (ERD Commander)
    1) the boot disk contains a lot of recover programs to use from DOS including repair boot sector and reset BIOS
    2) ERD commander boots the same as windows and allows you to try to repair your operating system
    With both you will have to read any instructions carefully.
    Have used both on occasions to repair and fix things
My desktop always shows not responding . It starts checking disks on startup . What's the problem ?
failing hard drive, recovering from a system errors programs not working properly. does it ever tell you what is not responding
Aug 08, 2015 | Computers & Internet
My brother laptop Compaq Presario CQ-42 after 3 month used , now appears " Boot Device not found Please install an operating system on your hard disk Hardisk - (3F0) " F2 System...
Fundamentally, it means that the hard drive or hard drive controller has malfunctioned. I'm assuming this is running Vista or Wndows 7 and that the hard drive is indeed a Sata drive?
(If it were running XP, the failure to deterct the hard drive could be caused by there not being a Sata driver installed, however, on Vista or 7, this should not be the case, UNLESS you changed the OS from what was installed originally?)
I would try to prove this by testing the laptop with another working sata hard drive and if that one is recognised in the Bios, then it comes back to your original hard drive being faulty. If this IS the case, then as its 3 months old and still under warranty, I'd take it back without tampering with it any further
Apr 18, 2011 | HP Pavilion dv5-1000us Notebook PC
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Aug 05, 2009 | Konica Minolta Magicolor 4690MF...
Error 0502
Please click on this link:
then type in the printer model in the selection X6170 and then choose Lexmark X6170 and support page will open then you need Error type 0502 and you will get it trouble shooting steps...
http://support.lexmark.com/perl/support/support.cgi
Good luck...
Aug 12, 2008 | Lexmark X6170 All-In-One InkJet Printer
Error 0502 from my fax series 6170
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
May 07, 2008 | HP 1040 Plain Paper Inkjet Fax
Lexmark x5150 all in one printer
Mar 04, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP NX9010 automatically shutdown
Definitely a software problem, somewhere along the installation process, the data on the CD is being read wrong. Try a different installation disk, and see if this fixes the problem. If not, then it could be that there is either a problem with the CD drive, or the IDE controller for the Hard Drive.
Feb 25, 2008 | HP Compaq Business Notebook NX9010
HP (D9896-69007) Motherboard Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
