Question about Kenwood KDC-225MR 200W Car/Marine SIRIUS Ready CD ReceiverKDC-225MR
SRC button on faceplate doesn't work
The SRC button on the face plate (KDC 225MR) doesn't do anything. But, I can work all functions from the remote pad on the transome of the boat. Is the faceplate bad?
  • wfnewell Jul 22, 2008
    The first "expert" told me what I already knew! Is there a test that can be performed?
    I cleaned the switches, faceplate, etc.& reset the unit to default.
    Genius:
  • 1,011 Answers
Dear sir/madam,
This is the dust problem for not working the face plate button. so you must clean the face plate.If the terminals on the unit or faceplate get dirty, wipe them with a dry, soft cloth.
If the faceplate of this unit is stained, wipe it
with a dry soft cloth such as a silicon cloth.
If the faceplate is stained badly, wipe the stain
off with a cloth moistened with neutral
cleaner, then wipe neutral detergent off.
Note:
Applying spray cleaner directly to the unit may
affect its mechanical parts. Wiping the
faceplate with a hard cloth or using a volatile
liquid such as thinner or alcohol may scratch
the surface or erases characters.
thanks
Good luck
"Don't forget to rate the solution"
Posted on Jul 22, 2008
  • Kenwood Master
  • 19,396 Answers
To test it you need to take apart the device and test for continuity (using a multimeter) the back of the switch.
If you can remove the button it is probably easier to spray some circuit cleaning solution on the switch circuit behind the button, often dirt and oxide cause this kind of problem.
  • Ginko
    Ginko Jul 22, 2008
    Go to a local electronics retailer and buy a product similar to this.
    Often you get this kind of problem because of oxide, particularly on marine equipment.
  • Ginko
    Ginko Jul 22, 2008
    If you cleaned the switch contact surface, behind the bottom (you need to remove either single button or plate) and the button does not work then it is probably faulty.
    To do a definitive test you should take apart the stereo, acess the back of the circuit board with buttons and check switch contact with a Multimeter, verifying if there is contiunuity when you press the switch.
    In this case I suggest contacting a repairman, it is not a difficult job but involves some risk of damaging the stereo.
    Guru:
  • 1,894 Answers
Yup. that can be a reason.
use a new one and check it.
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Thanks
Jan 06, 2011 | Kenwood KDC-8021 CD Player
I need to replace my marine (steering wheel) remote. what different models are compatible?
Me too. I ordered the new remote but can't find anything on how to sync it with the unit
Sep 13, 2010 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
What is the security code for kdc-891
1) Turn on the car.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
Jun 01, 2010 | Kenwood KDC-X891 CD Player
Protect
You have to reset your system... Use a pen to push a small button that's located in the front of the face plate. That will reset the system...If it gets stuck on standby, just push the SRC button on the face plate or on the remote..
Apr 18, 2010 | Kenwood KDC-MP235 CD Player
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
1) Turn on the car.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Need to reset the code for a kenwood kdc-mpv7019
If You Have The Remote Here Is Your Solution.
1) Turn on the car.
Thank You For Using Fixya.com Please Don't Forget To Rate My Answer
Jan 08, 2009 | Kenwood KDC-MPV7019 CD Player
Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Jun 05, 2008 | Kenwood KDC-MP2035 CD Player
Car Audio & Video Logo
273 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
