NorStar T7316 Corded Phone Logo
Posted on Apr 07, 2017
Have the Nortel T7316. This is an extension that is linked to our main office through a forwarding feature but, the phone lines are not tethered. While moving this phone in the office, somehow the voicemail code changed. It is not the same one I have written down. I entered the number too many times and the mailbox is locked. I have tried using feature 985 and tried entering 9, but the mailbox option never appears on the soft keys the only option is to exit (soft key). So my only option is to exit. How do I unlock the mailbox if I dont have the correct key and the mailbox option never appears. Is there a way to reset the entire phone?
5 Related Answers
Anonymous
  • Posted on Jan 07, 2009
SOURCE: Template for T7316 Phones
Go here, http://support.nortel.com/go/main.jsp?cscat=SWDETAIL&SoftwareOID=147467, and download the Desktop Assistant. It will allow you to create custom labels for that particular phone and a few others in the 7000 series.
Anonymous
  • 192 Answers
  • Posted on Apr 24, 2009
SOURCE: Nortel T7316E need to reset all the password
How to Change a Mailbox Password 1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Anonymous
  • 192 Answers
  • Posted on Sep 04, 2009
SOURCE: We have Nortel T7316. I have been locked out of
How do I reset a password on a Norstar Voice Mail mailbox?
Press Feature 983.
Enter the System Coordinator's Mailbox number (default is 12, 102, 1002, depending on length of extension numbers) followed by Password (default 0000).
Press MBOX.
Press CHNG.
Enter the mailbox number that is giving you troubles.
Press RESET. The password has been reset to default (0000).
Good Luck.
Anonymous
  • 45 Answers
  • Posted on Feb 23, 2010
SOURCE: looking for a manual for a Nortel Telephone -
http://www.wedophones.com/NorstarManualsLead.htm
Hope this helps you.
consultel1
george peters
  • 860 Answers
  • Posted on May 07, 2010
SOURCE: How do you change names on a Nortel T7316 phone?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
I have a 3-line Nortel T7316e phone. The feature to un-forward calls from one of my lines is not doing so. I need to un-forward calls from one of my lines.
Usually it should unforward calls by pressing the CALL FWD key again. Check out the user manual to be sure 100%. You can download the manual here: Nortel t7316
2helpful
How do I change voicemail greeting on Nortel Model T7316 phone?
feature 981
enter password
listen for promt to change greeting.
for main greeting
press feature 983
if 3 digit extensions enter 1020000 if 2 digit extensions enter 120000
press AA
press grtg
press 1
press rec
press ok to end recording
press ok
press rls
To Listen to the Greeting, press Play. To ReRecord, press RETRY. Press OK to accept Greeting.
I need to forward calls to another extension so the other person can get his calls when he is out Norstar T7316
To foward calls from one extension to another, press feature 4 and the extension number of the phone you want the calls to foward to. To cancel call forwarding, press feature #4 or press the cancel soft key.
3helpful
We have nortel t7316 phones in our office. one
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only
press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
2answers
Call forwarding
Your options are...
Option 1: Hit 7 then 2 then #. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit 7 then 3 then #.
Option 2: Hit * then 7 then 2. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit * then 7 then 2.
2helpful
3answers
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
4helpful
2answers
Call forwarding on t7316 nortel system
turn on feature 84.... turn off feature # 84
10helpful
6answers
Norstar T7316 can't make call forward work
This worked for me:
Feature 4, 0 1 (xxx) xxx-xxxx
Mike
Changing names on Extensions
Press "Feature **ADMIN", go to NAMES, Then go to Sets, and from their its just like texting
Forwarding calls between extensions
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
