Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer Problems printer won't pick up paper
    Problem Solver:
  • 14 Answers
Call HP and ask them to mail you a FREE printer cleaning sheet or two - sweet talk them and they DO have the authority to waive the shipping costs. if it's beyond warranty try the local stationary store.
Posted on Jul 26, 2008
Repeated paper jam
Paper maybe stuck together by excess humidity or static before loading into tray try 'whirring' the paper set you are going to use.or warm the paper -light bulb will do
Sep 26, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Will not grab paper. says out of paper when its not
You can try cleaning the rubber wheels with alcohol. Sometimes they become covered in dust and won't grab the paper.
Apr 08, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Printer i making a weird clicking sound. It won't print. It has error light On. Status: load tray 1 / Plain letter Toner level is 80%
check if there is a paper at tray 1. if so, may be the printer is unable to pick up paper due pick-up roller problem. try to remove the tray and look in the middle, there should be a rubber like roller. if its too glossy it cant pick the paper.
Sep 18, 2011 | Dell 1720dn Laser Printer
Paper feed won't pick up paper. tried to put single paper in but paper jam light goes on but no paper located. we think we need new rollers for the paper feed but not sure where to get them in...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
May 12, 2011 | Lexmark E232 Laser Printer
The printer keeps saying paper jam. I am using 65 pound paper and I changed the setting to card stock. Is there a trick to loading the paper?
I believe that if the printer is having problems picking the paper up it could be due to the pick up roller not having enough strength to pick up such a heavy paper. What you can do is make sure that the printer has the latest firmware installed as well as that the paper is properly placed and adjusted in the tray.
Jan 23, 2010 | Lexmark C510 Laser Printer
Canon mf3110 does not pick up paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
Printer won't pick up paper
You are having problems with the rollers. First, make sure you are using the appropriate paper for your printer. Then with a small piece of sandpaper, brillo pad, etc. Scrape it across the rollers gently. This will create a grip so the paper can be picked up. You will need to eventually need to replace the rollers.
Don't forget to rate this solution.
Jan 14, 2009 | Office Equipment & Supplies
Paper feed or pick up problems
The rubber paper rollers on your printer that picks-up paper may have wiered out. So try replacing them. This may occur when the rubber rollers get dirty also. In that case just cleaning them with a wet cloth will do the solution (no water drop should fall on the printer assembly).
Jan 06, 2007 | Canon Pixma iP6600D InkJet Photo Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
27 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
