Question about Hitachi 50GX30B 50". Rear Projection Television
Hatachi 50GX30B Okay what do you mean by that? I'll give you another clue on that problem when its really cool in the room the TV will stay on but if its warm in the room BAM it shuts off. So now what?
  • boyd171 Jul 23, 2008
    Oh sorry I'm new to this blog I thought it would post under the problem about the Hitachi 50GX10B that keeps shutting itself off. I finally found my TV guy and he thinks its the "convergence" thing. It sets on the right hand side of the set (if you are looking at the back of it) and its a silver box with a board attached to it. He's really awsome and is charging me $200.00 to have it replaced. So you think that was a fair price? The picture on this Hitachi is still very very good so I would actually hate to go out and purchase an 50' LCD. But this part has went out before - is this a common problem with that model? I purchased it about 2001 for $850 - new from I think Circuit City.
  • Hitachi Master
  • 8,617 Answers
I dont have a clue what your symptoms were, you have to keep responding to the origional post or I have no way to determine any previously posted items for your problem.
Posted on Jul 22, 2008
  • Sonny Berry
    Sonny Berry Jul 23, 2008
    Yes 200.00 is a fair price to replace the convergence ICs. It could verywell be that if your picture is out of alignment as a bad set of ICs will distort the picture and will cause the set to shut down. If the picture isnt out of alignment, then It wont be the convergence ICs that are shutting the set down. If you need more assistance please let me know.
Okay my window ac makes the room cold but when it gets really hot outside it stop what's the problem
It's called heat load. The insulation and the type of Windows in your home allow to much heat in at peak times that the a.c. can't keep up.
Jun 12, 2017 | Heating & Cooling
Air con split system r410p does not cool effectively. Never really has abt 5 yrs old any clues to help pls
if you have not had it fixed in 5 years ,
it could be the level at which it is installed
too small for the room size
doors and windows left open
insufficient gas upon installation
Call a technician for a proper diagnosis
Dec 29, 2016 | Heating & Cooling
Should the cooling fan stay on constantly?
No.
If the cooling fan stays on permanently when driving it means that your engine is overheating - and you would notice the heat!
Check your coolant level though.
It's probably the (faulty) switch that kicks in when the engine gets to a certain temperature .. like when idling along in heavy traffic .. and not switching off when the temperature drops.
An easy fix, assuming all is okay with your coolant system/cylinder head.
Give a mobile mechanic a call. These guys are good and cheaper than a workshop call out.
Nov 03, 2015 | Cars & Trucks
What does it mean when the oil light in the 1995 Cadillac Sedandeville 4.9 comes on
It can mean one of two things. Either your oil level is too low, meaning more than 1 quart, or your pressure is too low. The first thing to do is check the oil level in the engine and top it up. If the light goes out after this then everything is okay. If the light stays on you should get the oil pressure checked with a mechanical guage to get an accurate reading.
Get this done as soon as possible. Manufacturers don't give you much room with these lights, when they come on you are very close to the engine meltdown point. Hope this helps.
Feb 21, 2012 | 1995 Cadillac DeVille
I connected my brand new one Danby DPAC 7099 unit, but is not cooling the room. It only goes to 1 degree less than the actual temperature of the room and stays there forever. Is there something I should...
Your question "Should I wait before starting the unit, after bringing it from the store?" may be the answer to the problem. If the unit was turned on it's side or back when you brought it home in your car? Then yes. that is the problem. When AC Units, Dehumidifiers, etc are turned on their side or back, the refrigerant gas and the lubricating oil runs out of the compressor. It should not be operated, unit it's been setting upright for 6 to 8 hours. This allows all the fluids to run back into place.
If the above is the case. Turn the unit Off and unplug it for at least 6 hours. Hopefully, all the fluids will return to where they are supposed to be.
I hope this helped you and thanks for choosing FixYa.
Jul 23, 2011 | Danby DPAC7099 Air Conditioner
The TV just shut off on its own. Why did it act this way?
The TV will shut off when it's drawing more power than it can handle. It will also turn off if a sleep timer is set in the settings menu, or if it's overheating. If you have a lot of devices hooked up to the TV, I would suggest turning off or unplugging anything which isn't in use. Also if your TV doesn't have room to breathe, or if it's not well ventilated, certain components may be overheating, which may also cause it to turn off.
Jan 20, 2011 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 50gx30B Pincushion problem
Please let me know in which direction the picture is distorted. Does it bow in from the top and bottom or left and right?
Thanks,
Dan
Mar 06, 2009 | Hitachi 50GX30B 50". Rear Projection...
Tv wont show picture
Got a new tv and didn't pay any online service for a "solution"!
Jan 09, 2009 | Hitachi 50GX30B 50". Rear Projection...
Problemith 50gx30b
You want get information for free but you don't want give information for free?????????????????
Dec 19, 2008 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 50GX30B 50". Rear Projection Television Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
