Question about Brother HL 5140 Laser Printer
Drum Light The drum light comes on every time I print. The printed copy is good but the light always comes on. I've replaced the drum but the light continues. Whats the problem, what do I do to stop it?
  • annie540 Jul 22, 2008
    Coincidentally, I'm experiencing the exact same problem. We only replaced the drum 3/11/08, so the print quality is not an issue. I can't find a reset button, nor will shutting down and restarting help. Any suggestions would be greatly appreciated.
  • 3 Answers
You need to rest the drum count.
Open the toner door - press "Go" until all 4 lights light up
Let go of the button and close the door and you should be all set.
Posted on Jul 24, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: drum light
You need to reset the drum count. Open the toner door. Hold the "Go" key until all 4 lights light up. Let go of the button and close the door. That should reset the drum count and stop the blinking.
I've super G3, print comes light and very very light 2 inches from left. pl help
Print the copy counter of the machine, check if the life of the drum unit is already reached. If the drum is ok, then you have to clean the laser unit. maybe dirt is blocking the light coming from the LD unit.
Apr 12, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
I have a Brother MFC 8220 with a nonBrother cartridge and the original Brother drum. No problems printing until today. I tried to send a 4x6 piece of thin card stock through the front manual feed on the...
There are possibly 2 reasons why this is happening.
1. The drum unit may have been damaged in some way but I doubt it. Check fully that all contacts are in the right place at either side of the drum unit. A contact may be slightly bent.
2. Check the Transfer Roller is in its correct position. The transfer roller is the felt type roller that is positioned in the printer under where the drum unit goes. If this has got out of position then that could also cause the faint printing. Check contacts in printer are not bent.
May 19, 2011 | Brother MFC-8220 Fax
I own a Sharp Al-1655CS about 2 yrs old, I have a problem, the balck toner powder is exiting the back of the machine and copies are very light. The copy count shows 12,000 copies made. I have repalced the...
These are very good machines so I would see no reason to replace it. Do you have the operators manual? If so look up the setting for "toner save mode" and make sure it is NOT turned on.
The drum unit is good for at least 18,000 pages so I would not suspect the drum. I even reset the counters on the drum units and can get up to 36,000 pages on them. Do you have the machine hooked to a PC for printing? If so is there any difference between printer density and copy density? If so then the issue is with the scanner density setting. If the copy and prints are both light then it is a print engine problem. If several toner cartridges are doing the same light print then I would suspect that your laser scanner optics are dirty. There is a narrow strip or slot just above the drum unit that the laser beam goes thru to write the image onto the drum. This should be cleaned and then the machine re-tested. If no improvement is see then the machine will have to be dis-assembled and cleaned which would require a compentant service technician.
Good Luck and Thank You for using Fixya.
Aug 14, 2010 | Sharp AL-1655CS Laser Printer
Switched printer on to print unable to print drum light flashing-
Remove and reinstall drum / some times will reset drum switch.
Or the drum life has been used. Drum only good for 8 to 10 thousand copies.
Aug 12, 2010 | Brother HL-2040 Laser Printer
Drum light blinking
The light blinking means it's almost used up, when it comes on solid it will stop printing. If your prints still look good you can open the front door and hold the go button til all lights flash, and it will think it's a new drum. You can replace then when print quality gets bad.
Jan 06, 2010 | Brother HL-2040 Laser Printer
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Apr 15, 2009 | Kyocera KM-1505 Copier
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Drum light
Jun 11, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
