Question about RCA Universal Remote Control
TRYING TO PROGRAM A RCA UNIVERSAL REMOTE TO WORK WITH A PANSONIC TV. THE RCA UNIVERSAL REMOTE MODEL# IS RCR4258 I NEED THE DIRECTIONS AND CODES TO WORK A TV ONLY
  • 1 more comment
  • Anonymous Jul 23, 2008
    Need help programming my RCA remote
  • witney1 Sep 02, 2008
    I have RCA RCR4258/RCR4358 remote which was working fine. Now it doesn't respond to commands. I tried to re-set by removing batteries per RCA instructions, didn't work. Tried to re-program per instructions which call for a 4 didget code, my Panasonic (according to RCA website) only has 3 didget (012,013,038 &086) codes. Help.
  • Anonymous Dec 20, 2008
    at first it worked and then it stopped and now i need to reprogram it and i
    dont have the codes
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): TRYING TO PROGRAM A RCA - clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
Need directions to program rcr4258 remote
I just put directions up on site. Look for (Gregg BC MI)
Mar 17, 2009 | RCA Universal Remote Control
Tip
Directions for theis RCR4258/ RCR4358 Universal Remote Control directions for...
I can scan my directions for theis RCR4258/ RCR4358 Universal Remote Control Owner Manual PLUS THE LIST OF THE CODEES....I AM A LITTLE NEW TO THIS AND VERY BUZY GOING TO NURSING SCHOOL...B OARDS ARE IN 2 WEEKS,,,,,,,,,,,,,,,,,,,,,I KNOW I CAN PUT THEM ON A LETTER TO SEND,,,,,DUNNO OR YOU COULD REQUEST YOUR MAKE AND MODEL AND I CAN LOOK IT U[ FOR U.
Denita
on May 24, 2008 | RCA Universal Remote Control
HOW TO PROGRAM CODE INTO UNIVERSAL REMOTE
Several other fixya posts address this same remote.
The manual and codes can be found at http://66.77.167.109/rcaaccessories/docs/man/RCR4258_DOC_OM.PDF (found using RCA.COM )
www.rca.com
place model number in search box Search: RCR4258
Click picture of your remote.
Click support and manuals tab located under description
click manual link
Open Adobe Acrobat file.
If you have the manual and are sure you have followed the directions, then your tv or other device may not be compatible.
If you are looking for the code for a specific device, please provide more information.
Sep 08, 2008 | RCA Universal Remote Control
RCA Universal Remote RCR4258
ive got the same problem.
Did you ever solve it
Sep 04, 2008 | RCA Universal Remote Control
Rca rcr4258 universal remote code for symphonic st4819
Try the code settings for Funai; they build a lot of store-brand items.
You may not have all functions but normally you can find a code that will give you control of Power on/off, channels and volume.
Apr 09, 2008 | RCA Universal Remote Control
Televison & Video Logo
101 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
