Question about Basix BX-PC102 Calculator
Replacing ribbon 1. I cannot remove the cover to get to the ribbon, and 2. Office depot tells me they do not have a replacement ribbon for this calculator. Where do I get it?
If you have the same one I have, the Basix BX-PC 102 12 digit printing calculator it doesn't use a ribbon. (maybe that's why there's so inexpensive) It uses an ink roll - IR 40T. I'm searching for one locally now and can't find it. It seems you have to order them online.
Posted on Apr 10, 2009
How do I reset the Ribbon?
you don't reset the ribbon .. you have to replace it. it is called a thermal ribbon part number is Brother PC-501, or PC501 you can get it at office max or office depot or staples or Precision Roller for about $28.00
Apr 12, 2014 | Brother FAX-575 Plain Paper Thermal
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I lost the sensitivity because of some moisture formed inside the screen.. How much it costs to replace the screen?
Hi,before replacing the screen,why don't you dry out the LCD screen to get rid of the moisture,you can use a hand dryer to dry out the moisture of the screen after taking it out.If after drying the screen the problem remains,then you can go ahead to get a new screen.
Here is a detailed step on how to dissassemble your P1i;
STEP 1 Tools required: Torx 6 screwdriver, Phillips size 0 screwdriver
  • First remove the battery cover, battery, memory card and stylus. Remove the three screws you see
STEP 2 Run your fingernail around the join of the back cover and then pry the back cover off
STEP 3 Now remove the two screws you can see at the top of the phone
STEP 4
  • Now run your fingernail along the join of the front cover and you'll hear the clips, which hold the cover on, click. The front cover is on quite tight so use some force to pry the cover off
STEP 5 Remove the keypad and lift the part underneath from right to left, this will reveal two more screws. Remove these screws
STEP 6 Remove the metal plate that the screws were holding in place and you now have access to the ribbon which attaches the screen to the circuit board
STEP 7
  • Detach the ribbon to remove the LCD screen. The ribbon attaches like a plug and socket. Simply lift the ribbon up away from the circuit board to detach it
STEP 8 You have now removed the LCD screen then you dry, Reverse the whole process to reassemble. However,the LCD screen costs $92.if you have the reason to purchase it.
Thanks and take care
Apr 22, 2010 | Sony Ericsson P1i
HAVE AN OLD OLYMPIA MANUAL TYPEWRITER WITH SPOOL RIBBON (APPROX 2"). WHERE CAN I PURCHAE RIBBONS
You might try the office places (Office Depot, Staples, etc.). There are also online sources for ribbons. Here's one that came from a Google search for "typewriter ribbons". There were a few more, but this one had nice pictures.
Good luck with the hunt! Thanks for using Fixya.
Feb 12, 2010 | Olympia Office Equipment & Supplies
Olivetti lettera 22 replacement black/red ribbon ?
Try Office Depot or one of those big box office supply houses.The Lettera 22 is a pretty old typewriter, but the ribbons ought to be available
Mar 19, 2009 | Olivetti Lettera 25 Typewriter
Shredder runs continuously in AUTO position. It appears to use a photoelectric sensor for AUTO activation. I cleaned the window once with a swab and windex. It worked for a few days but is doing it again...
There are three reasons why:
1. paper particles or oil are still causing the optics to think you are inserting paper. Remove cover and clean thoroughly!
2. Optics are misaligned.
3. Optics are defective.
Feb 22, 2009 | Office Depot Ativa DQ60M Shredder
Need little guidence
Remove 2 screws from the left scanner cover, disconnect the flat ribbon cable from the formatter (main board). There are 2 silver self tapping screws in the rear and 1 each on the side of the unit that need removed. Slide the scanner section forward slightly and lift off.
Jun 18, 2008 | HP LaserJet 3330 All-In-One Printer
Basix BX-PC102 Calculator Logo
281 people viewed this question
Top Basix Office Equipment & Supplies Experts
k24674
Are you a Basix Office Equipment and Supply Expert? Answer questions, earn points and help others
