Error 1714. Adobe 7.0.1 cannot be removed. adobe.com/support/main.html - is unavailable. Installment pkg Adobe Reader 7.0.msi is missing. Adobe 8 will not download.
  • 5 more comments
  • grays332 Jul 23, 2008
    I am unable to remove Adobe 7.0.1 from the system.
    Please forgive me.
    I am trying to eliminate Adobe 7.0.1, as it is not functioning correctly, and causing other problems.
    I cannot see any documents that would have me jump to Adobe Reader 8. It will not even install.
    The quotes that I posted are what showed on the screen, as I tried to use Adobe.
    Windows 2000 Professional
    The assistance is insufficient.
    I did not understand what I was to copy and paste.
    I did more investigating of the computer, and here are some more facts.
    When I pulled up 'Search', the Adobe 7.0 entries did not work. There was no entry for Adobe 9.0, nor for Adobe Reader 8. So, something is stopping them.
    When I tried to currently install Adobe Reader 9, the flag stated ' Error 1714. The older version of Adobe Reader 9 cannot be removed.'
    Another flag stated: 'The feature you are tring to use is on a network resource that is unabailable'.
    Another: ' the path C:\Program Files\Adobe\Acrobat 7.0\Setup Files\RdrBig\ENU\Adobe Reader 7.0 msi - cannot be found.'
    Another: 'Fatal Error: Acrobat failed to load its Core DLL'.
    I hope this additional information will be of positive support.
    Thank you.
    Solutions from Adobe 1 through 4 did not help the errors.
    Could not find xMsicuu2.exe - perhaps I did not enter with correct phrase (?).
    Regarding Msisuu: the following showed after I ran the Windows Unstable Clean Up: 'Invalid Property array index. Run-time eror 381.'
    Ran Windows Instable Clean Up.
    On 'Add/Remove Programs' Adobe 7.0 was no longer there :).
  • grays332 Jul 24, 2008
    I have not yet pursued your last help ideas, because I now have the problem that I have no Microsoft Office Programs.
    The computer states they have not been installed.
    Please help. This is very serious.
    Remember, I did use the CCleaner and the
    Microsoft Windows Installer Clean Up utility
    Thanks.
  • grays332 Jul 25, 2008
    PLEASE - forget the Adobe Problem.
    All of a sudden, I do not have Microsoft Office, nor iTunes.
    Please tell me there is a way to undo whatever was done.!!!!!!!!!!!!!!!!!!!!
    These are serious.
  • 6,487 Answers
If you're using windows 2000 professioanl there's no option there like system restore like XP, if you stilll have the installation CD for microsoft office just reinstall it back and also do the same thing with Itunes..
Good luck.........
Posted on Jul 25, 2008
  • 13,433 Answers
You need to uninstall it by hand.
  • 19,396 Answers
Press start menu button.
Go to All Programs/Acessories/System tools/System restore.
Perform system restore to a date before you performed Acrobat installation.
Posted on Jul 24, 2008
    Master:
  • 555 Answers
See Adobe's instructions: Manually remove Adobe Reader (7.x on Windows)
When the uninstaller file is corrupt or malformed, it can't perform these steps programatically. So you get to perform them manually! (Fun!)
It's not that hard, actually. Most if it is just some cmd line instructions. Just follow the steps in order and it will finally be gone from your system.
Good Luck!
*If you find the solution helpful, please rate it!*
Posted on Jul 23, 2008
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Error "The feature... is on a network resource that is unavailable" or"Error 1714" when you update or install Acrobat 6.x, 7.x, 3D, 8 orAdobe Reader (on Windows)
Issue
When you install Adobe Acrobat or Adobe Reader, the installer returns one of the following error messages:
-- "The feature you are trying to use is on a network resource that isunavailable. Click OK to try again, or enter an alternate path to afolder containing the installation package 'Adobe [product] .msi' inthe box below."
-- "Error 1714. The older version of Adobe [product] cannot be removed. Contact your technical support group."
Solutions
Do one or more of the following solutions:
Solution 1: Browse to the original installation .msi file for the application you are trying to install or update.
1. In the error dialog box, click Browse.
2. Navigate to the original installation files for your product version and choose the .msi file.
Solution 2: Remove all previous versions of Acrobat and Adobe Reader, and then install the application.
1. Choose Start > Run, type appwiz.cpl in the Open text box, andthen click OK to open the Add Or Remove Programs dialog box.
2. Select Acrobat or Adobe Reader and click Remove.
3. When prompted, confirm that you want to remove the selected application.
4. Repeat the above procedure for all installed versions of Acrobat and Adobe Reader.
5. Restart the computer, and then install the application.
Solution 3: Attempt to repair Acrobat from the installation disc or cached installer files.
Important: If you do not have the cached installer files, and you havea downloaded version of Acrobat, you must download the installer again.This information also applies to the tryout edition of Acrobat.
To repair Acrobat:
1. Insert the Acrobat disc, locate the downloaded installer package, or navigate to the cached installer files.
Note: By default, the cached installer files are located at x:ProgramFilesAdobeAcrobat 7.0Setup Files. If the cached installer files arenot available, you must use the original media.
2. Start the installation again from this location.
3. Follow the onscreen instructions, and choose to Remove Acrobat.
4. Complete the onscreen instructions.
Solution 4: Run the Microsoft Clean Up utility before you install Acrobat or Adobe Reader.
Warning: The Microsoft Windows Installer Clean Up utility only removesregistry entries created by the application installer. Files and otherregistry entries for the application are not removed by this utilityand could cause inadvertent effects on the system if not removed. Ifyou use this utility, you may have to reinstall other programs that useMSI (Microsoft installer). Caution is advised. Read information aboutthe utility on the Microsoft website at http://support.microsoft.com/default.asp... .
1. Download and install the Windows Install Clean Up utility.
a. Visit the Microsoft website at http://support.microsoft.com and search for msicuu2.exe.
b. Select the article "You receive the ‘This patch package could not be opened’ error message in an Office program."
c. Click the link for the msicuu2.exe utility under Resolution Step 1.
d. Save the utility to your desktop.
e. Double-click msicuu2.exe and follow the onscreen instructions.
2. Identify the version of Acrobat or Adobe Reader that is causing theissue and correctly remove it from the system using the followingsteps.
-- If the error is generated by the current version of Acrobat or Adobe Reader:
1. Remove all updates that do not generate an error message.
2. Choose Start > Program > Windows Install Clean Up to start the Windows Install Clean Up utility.
3. Select the current version of Acrobat or Adobe Reader and choose Remove.
4. Reinstall the current version of Acrobat or Adobe Reader.
5. Apply any updates.
Note: If the current version generates another error message upon removal, refer to the documentation on that issue.
-- If the error is generated when an earlier version of Acrobat orAdobe Reader prevents the installation of the current version ofAcrobat or Adobe Reader:
Important: These steps require the installation media and serial number for both versions of Acrobat.
3. Select the previous version of the application and choose Remove.
4. Re-install the previous version of the application.
5. Remove the previous version of Acrobat or Adobe Reader using Add/Remove Programs, and then restart your computer.
Note: If the previous version generates another error message upon removal, refer to the documentation on that issue.
6. Install the current version of Acrobat or Adobe Reader.
Thanks
Good Luck
"Don't forget to rate the solution"
    Genius:
  • 2,028 Answers
You will need to go into the program file in the C drive and delete the Adobe manually. Empty the recycling bin and reboot. Then do a search from the start menu, all files and folders, keyword Adobe. If it finds anything write down the path to where it's located, then go in and delete it, empty the bin, and reboot. Repeat the process until the search doesn't find anything pertaining to Adobe, then install the new Adobe. You might also try a cleaning program to clean out any left overs in the registry or unused file extensions. CCleaner is a decent cleaner and can be found at filehippo.com
  • 1 more comment
  • Ryan Rogers
    Ryan Rogers Jul 23, 2008
    Have you tried installing the new version since the 7.0 isn't there any longer?
  • Ryan Rogers
    Ryan Rogers Jul 24, 2008
    The CCleaner wouldn't remove your office program, unless you ran the unistaller. Try a system restore to get the office back. if you can't get it back then I'm afraid you'll have to reinstall it.
  • Ryan Rogers
    Ryan Rogers Jul 25, 2008
    Did you try a system restore?
  • 4,889 Answers
Here are the solutions for solving this problem Error "The feature... is on a network resource that is unavailable" or "Error 1714" or "Couldn't find *.msi" when you update or install Acrobat 6.x, 7.x, 3D, 8 , 3D 8.xor Adobe Reader (on Windows) Click here to view the solutions for this from adobe.
  • 2,071 Answers
Just copy paste ;
Then you'll need adobe reader toopen the pdf
http://www.adobe.com/products/acrobat/readstep2.html
http://www.win-rar.com/downloadnow.html
(RUN WIN-RAR AS A TRIAL)
    Genius:
  • 1,665 Answers
Read relative forum;s comments at
http://www.adobeforums.com/webx/.3bc32b41
Microsoft Windows Installer Cleanup Tool.
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
Please read and follow the instructions carefully; this isn't a magic
wand, but a tool with a very specific purpose. After forcing an
uninstall you should always reinstall, then properly uninstall the
software.
  • 2,427 Answers
You will need to reinstall abobe 7.0 then uninstall it,,
then you can install abobe 8
use this link for 9
pls noth 9 will force 7 out then install it self or can bypass 7 and install itself overwriting the necessary files
  • 2 more comments
  • Rishi Roshan Ali Jul 23, 2008
    To get 7 out you will need to reinstall it
    You need to reinstall 7 to fix the missing files before you can sucessfully uninstall it :(
  • Rishi Roshan Ali Jul 25, 2008
    Sir your problem is occuring because your registery entries are messup up, loosing other progrmas means that it is getting more so by what ever you are attempting. You can try to reinistall the applications but chances are it will not. Cause the files are there but just not in the registery. What you can try Reinstall the programs that you have lost , and to uninstall the adobe you have to install it over it self then uninstall it this may be the only way to correct the registery..
    WARNING DO NOT USE A REGISTERY UTILITY CAUSE IOT WILL
    1.) delet the redundants thats needed
    2.) remove entrys for applicatins that are installed.
    IUf you have done this then i am very seorry but to inform you that you will have no choice but to format and do a clean install of windows..
    If it was done from a system restore
    you can undo the restore
    start>all programs>accesories>system tools>restore system
    follow the steps ton the screen to undo the restore..
    If the restore fails means that the registery is formulative and fargmented you will need to format.
  • 1,879 Answers
Greetings,
Try re-installing Acrobat 7 then reboot and Un-install.
Seems that you are upgrading to Acrobat 8.
After unistalling 7, reboot and install 8
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
  • monk3ybidzness
    monk3ybidzness Jul 23, 2008
    Go to www.adobe.com for more information.
  • monk3ybidzness
    Must have gone to automatic upgrade. It usually pops up and asks you if you want to upgrade or not. Accidental click.
    Just re-install Acrobat 7 then reboot and uninstall.
    Sergeant:
    Champion:
  • 347 Answers
Hello Grays332,
Can you please clarify your problem?
Are you trying to remove adobe? to install is or upgrade it?
Posted on Jul 22, 2008
  • 2 more comments
  • Santiago Vallejo
    Santiago Vallejo Jul 23, 2008
    Okay  Grays332,
    first of all, no need to apology. :)
    I will guide you trough the uninstalation proces, and if that dosent work i will keep telling you other solutions.
    First lets try a simplesolution.
    Click on:
    start  >  controlpanel  >  add/remove programs  >  (wait untill the list loads)search for adobe  >  right-click on i  >  select uninstal
    Good luck and if that didnt help, let me know
    Dahaka
  • Santiago Vallejo
    hello grays332,
    If you already try what i told you and it didnt worked,
    Then tell me something.
    Did you manually try to delete adobe, and then to uninstall them?
  • Santiago Vallejo
    Santiago Vallejo Jul 24, 2008
    Hello again grays332,
    If you already removed adobe, but by mistake also removed microsoft office, you will have to download it again.
    You can go to www.microsoft.com and search for the download for microsoft office.
    The full office programs cost arroud 40-80 dollars.
    The tiral is for free.
  • Santiago Vallejo
    Santiago Vallejo Jul 25, 2008
    Yes grays332, there is a solution,
    Go to start>>all programs>>accesories>>system tools>>restore system.
    Then select a restore point. This can be arround 2or more days ago.
    You wil lget office and itunes back, and adobe might reapear. If so, let me know and i will help you to remove it.
    Guru:
  • 1,894 Answers
"Adobe 7.0.1 cannot be removed" means??
you are not able to remove it from your system right??
    Genius:
  • 1,847 Answers
Uninstall the old version and then try.
Unable to read PDF files. I get ERROR 1311 (file Not Found) files\adobe\ reader 8.0\setup
The Adobe setup file is either unavailable in your system or it might have corrupted. http://get.adobe.com/reader/ http://download.cnet.com/Adobe-Reader/3000-10743_4-10000062.html
The above are the sites where you can download the adobe files.
Oct 14, 2009 | Adobe Computers & Internet
Need to delete Adobe Reader 7.0.9 so I can reinstall latest Versi
I was able to remove Adobe 7.0.9 by getting feed back from "question to google crowd"!
1. I had to download a program that removed the "setup" from the Adobe 7.0.9 on my computer.
2.I then downloaded Adobe 8.1 (with the understanding that since "7.0.9" now had no setup instructions" there would be no problem with the "8.1" download) -
3.Once "8.1" was downloaded I went to "ADD/REMOVE" and removed "7.0.9" - this time it worked just fine - no message that I had to find a folder with "7.0.9" .
4.After removing "7.0.9" I removed "8.1" with the ADD/REMOVE program;
5.All Adobe was removed from the computer..I then downloaded ADOBE 9 from Adobe's website.
6.I went to my portfolio to check it out and the pages came up without a hitch.
Goodluck to those who have had a similar problem.
peh51
Jan 15, 2009 | Tiny Computers B1996 19" CRT Monitor
Can not install adobe reader
download the latest version of adobe reader from http://www.adobe.com
Jan 15, 2009 | Microsoft Windows XP Home Edition
Cannot use reader 8.0,cannot remove it or install 9.0
oddly enough, you may find that updating the version 8.0 you have to 8.x will then allow you to remove it (or it will work correctly) can you open the reader manually in the programs list? if so open it, then go to help and check for updates. apply the updates. If they work you should be in good shape.
Dec 24, 2008 | Dell Dimension 8400 PC Desktop
Adobe installation
Create a new folder on your c: drive and call it downloads (c:\downloads), then browse to http://www.adobe.com/products/acrobat/readstep2.html
and click download now.
Save the file in the downloads folder you just created.
Open AdbeRdr90_en_US.exe in the downloads folder you just created.
That will give you the latest version and you should no longer have that problem.
Aug 01, 2008 | Tiny Computers B1996 19" CRT Monitor
Adobe problems
GO TO ADOBE.COM AND DOWNLOAD THE UNINSTALLER FOR YOUR VERSION TO YOUR DESKTOP.OPEN THE UNINSTALLER ICON ON YOUR DESKTOP.YOU WILL THEN BE ABLE TO REMOVE ALL INSTANCES OF THE SOFTWARE.IF YOU STILL CANT GET 7.0 REMOVED THAN IT IS BEING USED BY ANOTHER APP ON THE PC AND THATS WHEN THINGS GET A LITTLE DICY.YOU WILL NEED TO FIND OUT WHAT OTHER APP IS SHARING THE SOFTWARE.THE KEY IS TO GET WHATEVER PROGRAM ON YOUR COMPUTER THAT IS RUNNING 7.0 TURNED OFF.ADOBE NEEDS TO NOT BE RUNNING TO BE ABLE TO BE UNINSTALLED.BUT,I THINK THE UNINSTALLER SHOULD DO THE TRICK.GOOD LUCK.
Jul 22, 2008 | Microsoft Windows 2000 Professional for PC
Adobe Reader version 8
Try this fix,
1.dowload windows installer cleanup utility from the following link.
http://support.microsoft.com/kb/290301
Under more information, tab
2. Install and run the same from Start> All programs>windows installer cleanup utility.
3. In the box keep on selecting all items that say adobe and click remove. If you have multiple enteries might need to select them one by one.
4. Click on Start >My computer>Local Disk C:>Program files and delete the adobe folder
5. Restart your computer and again download and install adobe reader , it should work fine .
In case it still does not work and you need to open pdf files download
foxit reader from the following link
http://www.download.com/Foxit-PDF-Reader/3000-2079_4-10313206.html
Thanks
Mandeep
Jun 07, 2008 | Adobe Acrobat 7.0 for PC
I am having a problem with Adobe Reader 8.1.1. I am using Windows XP. Originally the program ran fine, but lately when I click on a link on a website that uses Adobe Reader I get a message that says...
do you the original installer of your adobe reader?
if you..when uninstalling adobe and the error occurs just browse for the .msi in your adobe installer and hit ok...
after it uninstall...download foxit reader and install it instead of the adobe reader....
hope this helps
^_^
Mar 16, 2008 | Computers & Internet
Adobe reader
i order to update the adobe acrobat reder run the set up it will automatically detects the old version and asks for update or uninstallation of old version follow the steps and ull get it installed after that if the setup did not detect the old version on ur computer then the existing version on ur computer is not installed properly or there is no any acrobat reder software in ur computer
Nov 21, 2007 | Adobe Acrobat 7.0 for PC
Adobe installation
Hooray! Found the solution. Seems the problem is you must have the Adobe Reader 7.0.9 installer on your system to be able to install 8.1.1. You can d/l version 7.0.9 (which includes the installer) here:
http://www.adobe.com/products/acrobat/read...llversions.html
Install the whole thing, then you should be able to install your 8.1.1, which will remove the 7.0.9 version in the process, but will use its installer.
Oct 20, 2007 | Tiny Computers B1996 19" CRT Monitor
Computers & Internet Logo
495 people viewed this question
David Payne
David Payne
