Question about Microwave Ovens
Jenn AIR JMC7000ADB
I am told that I need a fuse - but where in the world is the fuse?
  • rabdalla Sep 05, 2008
    My microwave went dead. I changed the fuse and after 1 use , it went dead again. What is the problem?
  • Trueva Nov 25, 2008
    I have a Jennair Oven/Microwave combination wall unit. The microwave if fine and the clock, etc., work on the oven. The oven will just not turn on! I am told it needs a fuse but the fuse is back ordered for months and I am getting upset. Where is that fuse? Perhaps if I saw it I could find one comparable at a repair shop. Help!
  • Microwave Ovens Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
How to get to fuse in my jmc7000adb
On this model, the fuse is located in an inline fuse holder is the wiring harness.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 24, 2012 | Jenn-Air JMC7000 Microwave Oven
Micro wave not working jen air
The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
Sorry
Apr 24, 2010 | Jenn-Air JMC7000 Microwave Oven
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
JenAir JMC7000ADB Transformer
Sears Parts Direct has them in stock here.
Mar 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Microwave went POP and stopped.
probably not the fuse. If it is, then something caused it to blow as a fuse is a safety device. Since microwaves can be dangerous due to the radio waves, here is what I've done in the past. I had Sears come out and diagnose the problem. Before tech left, I told him I don't have the money to fix it now but will do it in a month or two. I had him write down the parts I needed and the part numbers so when I do want it fixed, I do not have to start at ground zero. He was glad to help. I watched everything he did, and since I work on commercial microwaves, amana, it was no problem for me to order the parts and do the repairs myself. My microwave is a 1200 watt over my stove.
Keep in mind that microwaves are getting so cheap, that you may want to look into just what a replacement will cost.
Feb 05, 2009 | Jenn-Air JMC8100 Microwave Oven
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
Turntable no longer turns
Your problem is either a weak or slipping motor or a broken / cracked turntable coupler. If the coupler turns loosely without actually engaging the motor, it is bad. If the coupler is good or looks good, it's probably the motor. One test of the motor is to firmly grab the shaft with pliers and try to gently turn it. It should turn with some resistance and make a whining sound as it turns, since it is a highly geared motor. If the motor turns very very freely - or not at all - then it is bad. You can see an exploded diagram and order parts via the Jenn-Air (Maytag) Web site at http://services.maytag.com/abs/PartsStore.do?nextPage=psstartpage You will need to enter your full model, which is apparently one of the following: JMC7000ADB JMC7000ADQ JMC7000ADW Referring to the CABINET-BASE-CAVITY diagram found there, you will see: - REF 23 motor - REF 27 coupler One of those is likely the culprit.
Dec 06, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
262 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
