Question about Maytag PER5510 Performa Electric Kitchen Range
Clean Oven Door Glass
How does one access the oven door to clean the glass. There are 4-5 screws in the door but I am not sure if that provides access to the glass. My daughter has a Maytag range in the home they just moved into and the oven glass looks terrible (inside the glass) from cooked on greese, etc. I cannot see that there are screws on inside of oven door to access glass in order to remove it and clean it.
  • 1 more comment
  • reetzmaynard Aug 02, 2008
    While cleaning my daughters spectra oven, soft scrub got between the glass in the oven door. Can anyone tell me how are even if the door can be taken apart to clean between the glass. Thanks
  • Anonymous May 11, 2009
    I have the same problem with our 4 month old Maytag oven glass door. The oven is clean as a whistle but has one drip in between the glass panels.
    What is the sense of a glass door to view baking if you can't keep it clean in between. Inside and outside no problem.
    My model is MER5552BAS.
    Hope there are some answers out there.
  • Diana
    Diana Oct 30, 2013
    My door is now clean, how do we get the door back on?
Using a long stick/tool, attach a cloth to the end. Remove the drawer and look up at the oven door. There are 2- 3 openings that are big enough for you to reach the mess. Make sure that whatever you are using to clean the glass will not stay stuck inside, so make sure its attached securely. I used the end of back scratcher with a thin cloth attached to it. After a few attempts, I was able to completely remove the stain that was caught between the two panels. AND... I didn't need to remove any screws or dismantle the door. This could void your warranty.
Posted on Feb 17, 2009
    Scholar:
  • 50 Answers
It is much more complicated than that. There are usually more screws once you take out the first 5. There are a total of 3 panes of glass inside the door. If you are very careful to note how the door comes apart once you've removed the screws, then you will be able to do this yourself. Just be aware that this is going to be more complicated than it looks. Lay the door on your counter or floor with the outside of the door up. Take out all the screws around the outer egde of the door. Lift by the handle and turn the top half of the door over so the handle side is on your counter. You will see 2 panes of glass held by the same bracket on each side. You only need to take one of the brackets off and remove both pieces of glass. Now you can clean the inner most piece of glass. Then clean the 2 you removed and put them back. Now reasssemble the door in the reverse steps. Make sure that all insulation and seals are back in place.
Posted on Jul 22, 2008
  • 1 more comment
  • saxon751 Nov 06, 2010
    HI, solution is quite easy. Must have two people available for the job. First, remove pan drawer from the bottom of the stove. Secondly, remove the three white screws from the top of the door. Third, have your partner hold the front glass while you lay on your back and remove the five screws from the bottom pair brackets that support the door glass. The glass door will now slide down allowing you easy access to clean the inside of that pane and the other inside piece of glass. To finish simply reverse the procedure.
  • jsalamonric Nov 21, 2010
    I put off cleaning the inside glass because I thought it would be a major job. But with some hints from the solutions on this page and set out to clean the glass and found the task to be quite easy.
    First remove door from hinges by opening slightly and pulling up. Place door on countertop with oven side down and handle on top. Remove the 5 screws from the bottom of the door. Then remove the one screw on the right side of the door and remove the metal brace. Slide the top glass from underneath the handle. This will exposure the glass beneath. There are two panes of glass that can be removed. Unscrew the brace on one side and slide the glass out and clean. Remove the 3 screws holding the second pane of glass and slide that glass out and clean. You will exposure the inside of the oven glass for cleaning. After all glass is cleaned, reassemble. It only took me 15 minutes and my oven looks new. I wish I would have known how easy this was and did is sooner.
  • carolyn1211 Jan 02, 2011
    This was really not too complicated. See jsalamorics comments. I did have to remove both side brackets before sliding out the top glass. I have a genie double oven and the top door had an extra step to remove the middle glass. I am so pleased I can finally see clearly through both doors!
    I will also be able to clean the door in my rental unit which has two obvious streaks down the inside. Thanks!
How do I get the door back on, the hinges keep snappping shut?
Posted on Oct 30, 2013
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Aeg oven door
Most of those glass panels are a sealed pack and are not able to be separated. Usually there are screws around the edge of the door that holds the door together and if you were going to replace the glass you would take those out to separate the inside panel of the door from the outside of the door and that would give you access to the glass area. You could try that but I do not know for sure if you will actually be able to separate the glass to clean it.
Dec 03, 2013 | Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Nov 15, 2008 | Kenmore 33169 Gas Single Oven
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
May 24, 2008 | Frigidaire FES367 Electric Kitchen Range
Take the door off.
Lay it on a flat surface-front down.
Remove six screws- 2 holding handle and 4 a bottom.
Carefully remove top part door assembly from front cover.
Clean glass.
Reverse the process to reassemble.
Jan 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Maytag PER5510 Performa Electric Kitchen Range Logo
2,707 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
