GE air conditioner with air louvers on top of case - problem?
We just purchased a GE air conditioner model # ASM08LL and noticed that the top of the case has air louvers. We are concerned that this will allow too much water to enter the appliance during heavy rains. We have other window/ through the wall air conditioners and none have louvers on the top. One salesman told me that he has never seen that either and wouldn't buy one. We have not gotten any response to our emails to GE and not much help from its service call center. Is there a problem with louvers on the top of a case?
My Frigidaire unit also has louvers on the TOP of the case, and during a heavy storm, rain just POURS into the unit, and so much water builds up that it overflows the pan and then runs into the room. The AC is installed properly (tilted down towards the back), and I guess that works fine for normal condensation, but it can't handle the excess water during a rainstorm. This just an insanely bad design.
Posted on Jan 31, 2013
  • 143 Answers
Most fan motors are allergic to water. You should carefully examine the places where rain could go and decide whether GE has sold you a risky situation. After all, they have left it up to you to make the decision.
I wouldn't buy one with openings on the top and I wouldn't keep one after GE has demonstrated that not responding is the kind of help you will receive.
Posted on Jul 25, 2008
How does plastic head cover pull off on a head split system Panasonic split system air conditioner
Look for 2/3 small plastic covers for screws just under the louver(s) one at each end of the air discharge opening and one in the centre (maybe). Pry these off gently with a small screwdriver and you will see the screws underneath. Remove the louver first to make access easier. There may also be a screw in the centre just above the louver.
Once all the screws are out, the cover should lift up easily from the bottom and then release from the top clips. If it doesn't come off easily, you may have missed a screw.
Jan 26, 2016 | Panasonic Heating & Cooling
Kenmore portable air conditioner model number 407. 8312 6310 how do you add water to it
The best way is to pour water directly into the louvers on top. Make sure you don't get any of the electrical wet in the process.
Jul 30, 2014 | Heating & Cooling
Horizontal louvers
Get yourself up to the machine on a safe platform. Remove any covers that will come off easy, or tie them up out of the way. Remov e the filters. Often the whole front can be removed by just taking out a couple of screws.
Once exposed, look for something out of place. Put the louver back where it belongs to see how the hinge works. It may have jumped out of it's proper position. Ease it back in position and check it for freedom of movement. If it looks good, put it all back together.
Nov 26, 2013 | Carrier Heating & Cooling
How do I pull out the air conditioner from the sleeve? Something is holding the middle of the louvers preventing me from pulling out the ac. Help
if its getting hung up on the middle of the louvers check to make sure nothing has pushed the louvers in ,in that spot. Also look inside after you have front cover off to make sure all screws are out and it can have a simple catch lock on the inside to avoid accidental slide out.
May 27, 2013 | Friedrich QuietMaster Electric SS10J10AR...
My haier air condition doesn't have anything on vent to get cool air\r\ni believe it had styrofoam which got thrown away because we though it wasn't needed
I don't think a piece of thrown away Styrofoam is the problem. I'm more concerned that you may have also thrown the Owner's Manual away too. You said, "there's nothing on the front to get cool air in." Are you saying, that the front of the unit that has fixed louvers at the bottom and adjustable louvers at the top is missing? Because that's where the cool air comes out thru the adjustable louvers), when the unit is in operation. If the entire front of the unit is missing and the unit is brand new, you need to contact retailer you purchased it from ASAP.
I hope this helps and thank you for choosing FixYa.
Jul 29, 2011 | Haier HWR08XC7 Air Conditioner
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
Air conditioner blows hot air from dash
On most cars when you push a button or slide a lever to change your choice of location where you want the air to blow out louvers move inside the dash to redirect the air to your chosen location. When you switch from heat to AC other louvers move. These louvers are often powered by vacuum lines running from the engine. If one of these louvers is stuck or if you have a vacuum leak in one of the lines it may be causing your problem.
May 12, 2009 | 2004 Chevrolet Suburban
Its only blowing cool out of one side of the top
Due to design of window type air conditioners it is normal for more air to come out the right side air outlet at the top. Some units have air louvers to help minimize this natural action. Setting the air louvers will assist in redirecting the air flow.
Jun 13, 2008 | Haier Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
