I have a compact keyboard Model GP9110 and have not used it in some time. I am trying to get instructions and how to install it.
Gyration is the actual manufacturer of this keyboard.
"Gyration GP9110-001 Wireless Keyboard"Click Here for support page
Click Here for Troubleshooting
You may need to update the receiver firmware.
Click below for more information of how to install;
LinEAK - Linux Forums
Hello Rmmason,
Did you already installed the driver of your kerboard?
You dont need any special efforts for this..Just connect the Keyboard Reception Device in your system and Install any drivers if given along with it!..Press the signal in your Reciever ..Thats It Your done my friend!!..Reboot your computer and start using it..Hope this helps you out!!...Thank you..
Regards!!
HI,
All you have to do is just connect your keyboard to a USB port and it will work.If you have a driver cd with your keyboard then make sure you install it first on your PC and then connect your keyboard.
For more help please CLICK HERE
Please don't forget to rate or accept the solution.
Thank you for using fixya.
You have got a user manual for it.
just follow it
Removing the software and reinstalling it using a "clean boot" may
resolve the symptoms you are experiencing. Booting clean is a way to
eliminate programs from conflicting with installation of software.
1. Download the latest version of the software for your OS from the manufacturer's website.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4.
Locate the listing for the keyboard/mouse software and remove it. When
prompted to remove the keyboard/mouse drivers files, click Yes.
The following is the procedure for a 'clean boot' in Windows XP:
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hopefully, you should not have any problem now.
credits: IrishDruid
thank you
dont forget to accept the solution if you are ok with it.
I do not have an instruction manual. How can I download one. If I had the manual, does Sweet Rascal think that I would not use it.
I am trying to get some instuctions because I do not have any information on it.
This problem has not been resolved. Please forget my request. I am not satisfied with your service. Nothing said has pertained to my problem.
