Question about Gigabyte Computers & Internet
New system won't work with memory in dual channel
System freezes at random places - won't finish boot-level diagnostics like memtest86. Works fine with both DIMMs in bank 1 and 2, but goes into failure behavior if memory is configured dual channel
Gigabyte GA-P45-DS3L BIOS F6
E7200 Core2Duo 2.53Ghz 1066Mhz FSB 3MB L2
SuperTalent 2x2G DDR2-800 PC6400 CL 5-5-5-15 (T800UX4GC5)
Seagate 500GB SATA2 7200 32mb HD
EVGA 8800GT 512MB Superclocked Edition
Ultra X-connect X2 550-watt
Vista x64 SP1
  • mxcrowe Jul 22, 2008
    venkapatcha,
    Why do you believe it is the RAM? Why would the RAM work fine (20 passes of Memtest86+ no errors) in single channel but not in dual channel? I don't know what's wrong, but I'd think mobo before RAM. What am I missing?
  • 101 Answers
Change RAM (SuperTalent 2x2G DDR2-800 PC6400 CL 5-5-5-15 (T800UX4GC5) this part
Posted on Jul 22, 2008
I have a think center pc . he has some memory proble.ram problem.
RAM diagnostic tools/utilities
The following free utilities can test your system's RAM, which must be operating 100% all of the time or serious data corruption and/or system failures (that can be very difficult to track down) will occur. Note that they take a long time to go through their various tests. As long as you can boot the computer from a floppy disk or CD, if you copy the utilities to such a disk, you can run the diagnostic tests.
Microsoft Windows Memory Diagnostic tool - with full instructions on how to use it. - http://oca.microsoft.com/en/windiag.asp
Memtest86
- latest version - http://www.memtest.org/ and http://www.memtest86.com/
Dec 02, 2010 | Lenovo Computers & Internet
Computer starts and works fine for some time then it freezes and does nothing computer is an hp a1133w, I have replaced the heattransfer paste thinking thast is a heat related issue but it did not work
Three things could be it:
  1. failing disk drive
  2. failing memory
  3. virus
#1 Run manufactures diagnostic. Their web site will have the download
#2 Google MemTest86 and run
#3 Go to TrendMicro.com and scan for viruses.
Aug 14, 2010 | HP Computers & Internet
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
Aug 05, 2010 | Evesham Evolution PC Desktop
I have a Dell E510 that will not boot up. It has power and I get error codes 3 and 4. I have reseated the memory and replaced the memory to new memory and tested them one by one in the first slot. The...
Ok what you might try is get a new hard drive and install windows on there and see what happens. Also if you are able to before you try a new hard drive you should do a system restore and restore it back to the day that windows was installed.
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
New ram makes my pc freeze
Many motherboards when booting from dual sockets wish for ram either of same manufactuer or same capacity per stick
Jan 14, 2009 | Biostar GEFORCE 6100-M9 Motherboard
My Abit NF7-S v2.0 only works with one memory module at a time
I have read that there are dual memory controllers (duel channel) and that when you use 2GB like that you are using 1 memory controller for each stick. Maybe one of your memory controllers is bad... maybe popped a cap? Sounds like time for a new MB. See this thread...
http://www.motherboardpoint.com/t61060-nf7s2-can-it-use-highdensity-memory-chips.html
Oct 23, 2008 | Abit nForce2 NF7-S2 Motherboard
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Can not upgade memory from 2G to 4G
have you checked the frequency of the new ram you are using if its not of the same type and of same frequency as of the another one your system wont boot
Sep 14, 2008 | Acer Aspire™ T180 PC Desktop
Memory installation
bev,
all the DIM's must be of same type and same size to work, otherwise it creates problem, like no boot, boot with lowest memory etc.
There is no problem in your PC, its technical issue you can not use two ore more different type RAM at the same time in a motherborad.
Thanks
Iqbal
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
My system freezes
What memory do you have in it?
If the memory is not dual channel it will freeze
Nov 06, 2007 | ASUS P4P800-X Pentium Motherboard
Open Questions:
Computers & Internet Logo
193 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
