Question about Panasonic Audio Players & Recorders
Problem with technics SL-L20 linear tracking turntable
Hi this is John I'm hoping somebody can help me. I have a technicslinear tracking turntable and the grease has become sticky and driedup. The tonarm has a problem tracking the record because of the grease.I tried removing the old grease and replacing it with phonolube butit's for gears. The grease I'm looking for is silicon based and I thinkit's similar to the kind they use in sunroofs which is for slidingsurfaces. I appreciate your help. Thanks!
  • 515 Answers
Not sure what your question is? Linear tracking turntables also have an assortment of gears and pulleys which make it function correctly. Sometimes the drive belt will break, other times, the gears will crack. You will have to open her up, and take a look inside to see if there are any components which are damaged. There may also be grease applied to the gears, which might also be preventing it from moving properly.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Posted on Jul 23, 2008
Technics SL-L20
Hi, any turntable and amp are compatible. Modern amps however without dedicated phono inputs require the use of a preamp. Cheers john. Stylus City
Apr 29, 2014 | Technics Audio Players & Recorders
Fuse location of technics SL 1200M3 turntable
Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
Apr 01, 2014 | Technics SL-1200M3D Turntable
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
Trying to track down a tonearm plug in connector and stylus for an SL-BD22. Is it possible to get the connector separately? Can you recommend the best place to get them?
Hi, Is it the headshell you want like this?
If so I have 1 in stock $39.90 USD. I also have an original Technics EPC 24 P mount cartridge with stylus which were fitted to SLBD series $49,90 USD. Cheers John. styluscity@gmail.com
Nov 10, 2011 | Technics SL-BD22 Turntable
Turntable technics sl d93 when arm in ready to
hi, there is a rubber grommet at the base of the tonearm on the left side. Remove and insert a flat blade screw driver. Adjust and test until remedied. Cheers John. Stylus City.
Jan 10, 2011 | Technics SL-1200MK2 Turntable
Suggested lubricant for Technic SL-5 linear tracking tonearm
technics used special grease for lots of their products, any good quality grease will do but use sparingly
Apr 07, 2009 | Audio Players & Recorders
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
Jan 03, 2009 | Panasonic Technics SL-DZ1200 Turntable
Technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 30, 2008 | Technics SL-BD22 Turntable
1,104 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
