Audio cd I have written them at 16x which is the lowest setting it will go to, when I put the written cd back into the drive I have notced that Itunes comes up instead of wmp
  • 385 Answers
You can always choose to play via WMP though. You can open My Computer and right click on the cd and select Play With or Open With and select WMP. The thing is, does it play on other cd players besides the comptuer's?
Lolita
Posted on Jul 22, 2008
CAN I WRITE AUDIO CD IN 8X SPEED
yes, you can write it in 1x or even 42x if you want. The only thing that can happen is a chance of data loss but not quality. Also some older stereos could run into issues not just cuase of the write speed but cd incompatibilitiy. Audio CDs are nothing more than WAV files written on a CD and then a table of contents added as a CDFS file system.
Jun 29, 2011 | LG GH22NP21 DVD-Writer - Internal...
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
What is 1X, 2X,4X,8, 16X WRITE SPEED
HI. These settings are indications of the rate of speed that the actual CD-ROM disk will spin at. The rotation speed can be adjusted to the lowest, which is 1X, and the highest, which can be up to 54X; Depending on your brand of CD_ROM drive. Adjusting the settings to a 16X or higher rate, will decrease the burn time.
  • NOTE_ A high spin rate speed will decrease burn time, but it will also increase the chance of a writing error, as well.
Aug 19, 2010 | Computers & Internet
My MATSHITA DVD-RAM UJ870QJ ATA will not recognise an audio cd
i tried this and it worked when nothing else would.
http://sites.google.com/site/matshdvdfix/
Feb 21, 2010 | Acer Computers & Internet
Burning using Tape2PC
if you are using itunes and you have a cd burner on the laptop...you just pick approx 10-15 tracks from itunes (it also depends on how big the mp3/4 tracks are) place your correct (cd +/-, 16x or 8x) type of blank cd in laptop and burn ...
Sep 25, 2009 | ION Audio TAPE2PC Single Cassette Deck
I get an error 4280 when I attempt to burn an audio cd
Apparently a common error; if you google error 4280 you'll get several different versions of what is happening. Some blame the Sony CD's other blame Dell, HP, etc...like I said there is a long list so I didn't want to pick out just one, it depends on your Computer type, combined with the CDs..so go ahead and take a look. Personally from reading some of the fixes I came up with; don't use Sony disc and run at 16x to get rid of the error. Hope this helps..
Please rate this solution.
Mar 18, 2009 | Computers & Internet
Pioneer DVD-RW DVR-106D VI.07 isn't working propperly
use winrar or download DVD REGION and use trial should work
Feb 03, 2009 | Pioneer Computers & Internet
Not able to write dvd,though cd can be written
check the dvd some dvd are not work on certain manufactures, hp doesnt allow rewrite capabiliter on record dvd. does the manufacture dvd -r or +r or -+r, just write too..
cd-r, cd+r or cd-+r,
some cd cd rom clv, cdrom cav,
the speed of the format may be differant from cdrom and dvd
if dvd 5x and you are trying to use 16x they are not compatible.
rod
Feb 03, 2009 | Computers & Internet
Won't reed CD
thanx
XD
if it is a audio cd itunes must act like that
but u can get to my computer then u will find the contenets of the cd inside it!!
plz tell me if i helped u so i can help u further
and rate me as good as u can
Nov 18, 2008 | Apple Genuine Pioneer "SuperDrive"...
Playing but no sound
HI there check that the sound control on windows that the cd audio isn't set to nute or is too low. Failing this check that the audio cable is in the back of the computer also check that the audio cable is inserted in the cd drive inside the computer (Little gray cable).
Thanks J
Jan 11, 2008 | ASUS DRW-1608P beige ( White ,beige,black...
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
