Question about Jensen VM9410 Car DVD Player
Face of deck
The power knob on the right bottum side is gone off my deck and i need to find a way to buy another one
I had the same problem andcontacted Jensen and this is the email they wrote me back:
#1710022190001 Play / Enter knob $3.50
There is a charge of $6.50 for domestic ground shipping and handling. New York
State residents add 8.625% sales tax. You may pay for your order with a check,
money order or any major credit card.
When ordering with a check or money order, make it payable to Audiovox. Please
include the part number, your name, telephone number and the ship to address.
Send the check or money order to:
Audiovox Electronics
150 Marcus Blvd.
Hauppauge, NY 11788
Attn: Parts Department
When ordering with a credit card, please get back to me with the credit card
number and expiration date, your telephone number, the name and address EXACTLY
as it appears on your credit card statement and the name and complete ship to
address. If it is a VISA, we also need the last three digits on the back of the
card.
Posted on Sep 08, 2008
How do I level the deck on a John Deere X500 mower
FInd and buy a deck level guage (makes it so much easier) photo.25191349-sc2hyhwnmj3wm0xvqhiyjoyo-1-0_0.jpgAdjust the front tire pressures to 14 psi. Set the rear tires to 10 psi. Make sure that the mower is on level ground,concrete driveway or garage floor. Set you deck height knob to 2.5 inches. Move the blades to where the blade tips are pointing to the side of the mower deck. Level the deck side to side by adjusting the lift link nuts,15mm or 17mm wrench. Get the side to side as level and possible and close to a number or mark on the guage. Move the blade tips to the front of the mower deck. Check the front to back and have a 1/8" to 1/4" lower on the front of the blades than the back. 18mm and 19mm wrenches for the front adjusting bracket.
Oct 06, 2014 | John Deere Garden
Were is erg valve on 93 lincol town car
SHOULD BE RIGHT SIDE OF UPPER MANIFOLD WHEN FACING CAR 2 WIRES COMING FROM IT
May 09, 2012 | 1994 Lincoln Town Car
No display, everything else works fine.
you may have bad solder connections on some surface mount resistors inside of the deck, they are on the right side of the deck as it is facing you. there are about 7 or 8 resistors or so. not sure of the exact number right now as it varies from deck to deck.
Oct 26, 2010 | Kenwood KRC 535 Cassette Player
How to adjust mower deck height
There should be two threaded rods with a nut on them that goes from the frame to the deck. Check the height of each blade and which ever side is out of balance you can disconnect that sides rod (usually held onto the mount with a clip or cotter pin) and turn the rod to either raise or lower your deck until it is level.
The above was for leveling your deck.
If you just need to raise or lower the deck depends on if you have a lever on the right side with a push button on top just depress the push button and push forward to lower or pull back to raise.
It might have a round knob that you turn to raise or lower.
Good luck
Sep 03, 2009 | Garden
What way do u put the sway bar bolts in Pins on top or bottum
the links are marked left and right top and bottom. The bolts face toward you in the strut
Jul 15, 2009 | 1996 Mercury Sable
How can a i get a replacement module for my right side of EP2500?
Hi, you could find one at the nearest Behringer parts outlet, that might cost some money... or you could build one. You have one in the amp. Copy it.
Jul 07, 2009 | Behringer EUROPOWER EP2500 Amplifier
Deck won't eject
use the manual reset on the face plate. its located to the right of the rotory knob. you will need a pen to push it in. then remove the face plate and reseat it.
Feb 15, 2009 | Alpine CDA-9830 CD Player
Ribbon cable broken and now cannot open the face plate
You need to take the unit apart to fix the cable since the other end of it plugs into the board inside, it's pretty easy to take apart though. Good luck!
Feb 09, 2009 | Pioneer DEH-P8600MP CD Player
I have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Nov 09, 2008 | Dual XDMR-7700 CD Player
Jensen VM9410 Car DVD Player Logo
114 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
