Question about Nintendo DS Console
Nintedo ds wont turn on
My nintendo ds wont turn on. The battery is fully charged and when plugged in the orange light flashes once then turns off. Does anyone have a soulution?
  • Anonymous Aug 02, 2008
    nintendo got wet from rain,flashes once and goes off .
Why is my screen white
Posted on Aug 09, 2008
My DS lite wont charge - the orange light flashes once, then nothing.
Hi, it might be the fuse.
Does the DS turn fail to turn on?
Does the charge light just flash briefly when you plug in charger?
If so it will be the fuse.
If the console it out of warranty, maybe you or someone you know can fix it.
Check out the following youtube videos
Good Luck
http://www.youtube.com/watch?v=io5iN42q3VQ&feature=related
or for an easier but dodgy method
http://www.youtube.com/watch?v=GYWt811XNDs&feature=related
Jan 24, 2011 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
It wont turn no matter how long i charge it
does the orange light flash of a few seconds after you plug it in? If it does, I think that it is a battery problem. After a lot of charges, the battery's capacity decreases. If the orange light just flashes, I would try a new battery http://www.nintendorepairshop.com/shopdisplayproducts.asp?id=191&cat=Nintendo+DS+Lite+Batteries for ds lite battery or http://www.nintendorepairshop.com/shopdisplayproducts.asp?id=188&cat=Nintendo+DS+Batteries for a ds battery (both $8)
Jul 15, 2009 | Nintendo DS Lite Console
Battery is fully charged but it still wont power up no lights when plugged in to charge
Hook up only the ac adapter to the DS to see if it turns on. If it does then we know the ac adapter works. We know the battery got fully charged but the system isn't turning on with the battery that is fully charged up.
I would say your battery is defective but you won't really know until you fully charge up a known good working battery and test it out.
Jun 29, 2009 | Nintendo DS Lite Console
My ds wont charge or turn on
Have you tried a different battery before anything else? Most of the problems I get with these are the battery
May 28, 2009 | Nintendo DS Lite Console
Putin in charger orange light flashes then goes off an doesnt cha
Your DS is either fully charged or the battery got damaged/wet. When you play the DS, is the light red or flash red? If it does, then the problem is with your battery. http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Click on your country, then "System and Game Problems," then "Power and Battery Charging Problems."
Hope this helped.
Apr 15, 2009 | Nintendo DS Lite Console
Wont turn on
The orange charge light turns on when you plug it in and goes off after a short time? If so, it may be a problem with your battery. Does the power light flash green when you turn it on? As batteries are recharged more, they slowly lose their capability to hold a charge. i would suggest borrowing a battery from a friend, if it works, you need a new battery.
Mar 30, 2009 | Nintendo DS Console
Ds is plugged into charger. But when i try to
What is the orange charging light doing? If it is just flashing on, or only staying on or a minuet, that means you need a new battery. The orange light foes on when the battery has been charged to its maximum capacity. After each charge, the capacity is decreased. So if the orange light is on for only a short time, get a new battery.
Feb 28, 2009 | Nintendo DS Lite Console
First, you can try swapping batteries with a known working unit and battery. Failing that, go to Nintendos website & plug in your DS serial # to check if it's still under warranty (1yr). If so, mail it back to Nintendo they will usually fix for free. If older than 1 year, they may still fix it, but you need to call the toll free number & arrange that. That usually costs around $50 dollars. Their are 2 fuses inside the DS (not easily replaced at all)! that may be blown.
Aug 14, 2008 | Nintendo DS Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
120 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
