Aficio 220/270 copier showing Functional Problem SC541, can anyone tell me how to reset?
Sc541
Posted on Apr 09, 2010
Functional problem sc 541 for richo aficio 1022 photocopier
SC541 = The melting temperature measured by thermistor is less than 71 C
The problem lies in the fuser:
- Thermistor fuser defective or incorrectly installed
- Fuser Lamp failure
Solution: Replace Fuser
Jan 05, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
My aficio 1515 have a code SC541
sc 541 is a fusr error. please email me on ronils_singh@yahoo.com.au so i can email you a procedure to reset the code.
Sep 28, 2010 | Ricoh Aficio 2015 Copier
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Hello, We have a Ricoh Aficio AP410N Laser printer. It stoped working and gives the error code SC514. Resetting it didn't help. Could you please advise? Many thanks
There is no SC514 on an AP410N. Do you mean SC541? SC541 is a fuser code that a technician has to reset. It could be something as simple as a power spike, or it could be a dirty sensor or a blown board.
Jun 01, 2010 | Ricoh Aficio AP400N Laser Printer
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
At start-up printer codes out a sc541 turn off then on
It's a fuser error. Fuser may need replacing, and fuser codes can only be reset by a technician, to prevent further damage
Feb 26, 2009 | Ricoh Aficio CL7100 Printer
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
268 people viewed this question
jasbo
jasbo
