Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
No Manual We just purchased a used Frigidaire gallery series front loader washer and dryer and it did not come with a manual. Is there any way you could send me one? we think it is a 2003 or 2004 model
  • 639 Answers
Please go into fixya.com and give me a rating,Solution solved ,etc..
Neil
Posted on Aug 24, 2008
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
Frigidaire gallery remove pedestals
There should be a bracket on the front and back of the pedestal with screws going into the bottom of the washer or dryer. Many times it is inset so you do not normally see it. Remove the screws in the bracket and it should come right off.
If you do not have brackets it might be screwed in from within the pedestal body in which case you would have to take out the drawer to get to the screws.
May 19, 2012 | GE WBVH6240F Front Load Washer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Door opens on wrong side
I don't think you can on a front loader washer.. on your dryer you can see how they have screw covers for interchanging, but on washer there are none.. sorry.. good luck..
Jan 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Attach washer to pedestal
there should be bolts that come with pedestal so you need to take your legs out of the washer now lay it on its back then bolt the pedestal up to it and if the pedestal dont have feet put the ones out of the washer on it
Dec 31, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
212 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
