Question about Kenmore 64802 Top Freezer Refrigerator
Need to know how much oil to put in a Matsushita Compressor #DC57C84RCU6 This is in a model #GSS22JEPAWW G.E.Side by Side Fridge
  • Anonymous Mar 21, 2014
    i have a compressor labeled fn91f206 so let me know specification and cataloque
My GE GSS22SGPASS which uses the same compressor has a tag which indicates it was charged with refrigerant 4oz., oil 250 cc.
Posted on Jul 31, 2008
Hi, I have hotpoint ref. The freezer is fine & cold. The fridge part has been warmer. I cleaned coils, but the compressor is hot to touch. It's model DC57c84RCU6. Any advice?
I have the same refrigerator and had the same symptoms. It was the defrost timer. It is located behind the back wall panel of the refrigerator side. Mine was a side by side. The part was $65 from the repairman, but I'm sure it was marked uup. He unplugged. Unscrewed about 4 screws, removed the timer (which was a a bar shape almost like the old centers of a metal ice tray) It took him about 15 minutes and it was $165 for the trip and parts. Next time I do it myself, because he said it is very common with these pieces of ****.
Jul 31, 2012 | Hotpoint Refrigerators
I need the capacitor size for a Matsushita compressor model #2P19C3R126A Thanks
It just so happens that I am about to replace the compressor,on a marine A/C unit that uses the Matsushita 2p19c3r126a compressor. I believe it uses a 30 mfd capacitor.
Jun 10, 2011 | Heating & Cooling
I'd lke know, the HP of this compressor MATSUSHITA DB91C14RAW5 thanx
According to the information you have given it is a one quarter horsepower compressor
designed for R134 refrigerant. It runs on 115 volts.
Apr 03, 2011 | Matsushita DD73C14GAU6 1/4 HP R134...
I just purchased a two door Emerson mini-fridge yesterday. I got it at Target and they put it in my car sideways even thought the box said not to. I didn't realize that I should have waited to turn it on...
yes this is for sure happening because you put it on its side. my suggestion is to 1 - turn it off. 2 put it upright 3 leave it for half an hour and then turn it on.
the sound you hear is the compressor trying to pump oil because you had the fridge on its side. Stand it upright to allow the oil to drain back to the sump and then try.
because the compressor has already pumped the oil - it may make the noise again for a while but it should pass ok.
worst case is that the compressor seizes due to lack of oil or that the filter gets blocked up. but both of these are unlikely.
hope this helps
koolman77 (refrigeration technician)
Feb 07, 2011 | Emerson (025806803716) Wine Cooler
My Maytag refrigerator Model # MSD2651HEW (26 cu ft , side by side) would not cool there was a rrrrrr noise with a clicking noise and the compressor would heat. I got a factory OEM part from Sears and...
Did you lay down the fridge while cleaning it? if so: Normally if you lay down your fridge the compressor oil is running into the pipes that carries the gas to cool the inside. if that oil is in the pipes you have to shut it down for at least 2 days for the oil to return to the compressor, if not layed down, the chances are that you running out of gas and had to have it refilled
Dec 11, 2010 | Maytag MSD2651 HE Side by Side...
Fridge not cooling,unfortunately collected by car and the fridge was transported on its side.Its been off and standing for days but still not cooling when switched on,is there a remedy
It is possible that the compressor oil had pumped into the system and is thereby causing problems in the heat exchange cycle.
Put the fridge off and keep it standing for more than 24 hours to allow the oil to come back to the compressor.
After the time limit put the fridge on and watch the noise of the compressor to be pumping earnestly with a good whining. If not check onthe main capacitor or relay( if clicking).
If there is no ICe formation in about 2 hours, it is possible that the compressor is weak , gas is leaked and needs an overhauling.
Sep 16, 2010 | Refrigerators
Need a replacement compressor < 8 " high for older refrigerator
How can you have a R134a Compressor that is 32 years old. That gas was not even available then. What you are asking is impossible, unless you are asking can you change from possibly R12 to R143a. The answer is yes but it would probably be too costly. you see R12 ran with mineral oil whereas R134a runs with Polyolester oil. the system would have to be completely flushed out of old oil, and the expansion device ( capilliary tube ), would have to be changed and cut to the correct length to appropriate the correct displacement of gas.
Apr 17, 2010 | Matsushita DD73C14GAU6 1/4 HP R134...
GE Side-by-sides compressor is not coming on.
Pull away from wall and unplug remove cover over compressor and feel top. If too hot to keep your hand there leave unplugged. Contact me and I will assist you in your repair and diagnostics. We will need to examine the motherboard and test points. I do have the information you will need. Thanks, Sea Breeze
Jan 22, 2010 | GE Refrigerators
Hi i am a refrigeration mechanic and i need a compressor for a chest freezer, here are all the reference numbers on the compressor, can you tell me the specs so i can get a match. SMH 2598133 Model no:...
i think any 1/3 hp 134a compressor will work you just have to make sure the fitting are in the right place,i got mine on ebay for $50 or you can check sears.com(parts) or repair clinic .com,let me know how you do-mike
Oct 28, 2008 | Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
681 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
