Question about Intertherm Heating & Cooling
I have an intertherm AC unit (model E2EB-015HA) and the inside unit is leaking and damaging my floor. We discovered this last summer and assumed it was a combination of condensation from the unit and freezing up. As it did freeze up and we caught it rather late. I did a good cleaning, filter replacment, and checked the line running out of the water-pan and it was not clogged and water was flowing well. I fixed some floor damage in my hallway and kept a close eye on the unit. This summer it has started again and now the water is flowing the opposite direction and is damaging the floor in my bathroom. The line is still flowing well and we have been watching the unit for freeze-ups. What else can leak on this type of a unit. I'm at a loss as I don't really know what to look for or how to approach the problem. Any help would be appreciated, Edward J.
  • ebjohnson123 Aug 05, 2008
    Where is the front water pan located?? If its the same pan that is under the triangle shaped condenser unit then I know its not leaking - if its something else I'm not sure.
I realize this post is a few years old, but I keep having the same problem. Just got out from under my trailer draining water out of the insulation. I noticed when my unit was running that the water in the pan was being pulled back towards the inside of the coils. After cleaning it up I noticed that where the coils sat in the pan had rusted a hole in a few areas and was allowing the water to get inside wetting the blower and everything inside along with my floor bad enough that water was coming up through the tiles when we walked across the floor.
Don't know if this was the right move - wanting some insight, but I siliconed along the bottom of the pan to try and seal the rusted areas.
Posted on May 20, 2012
  • 143 Answers
It's very rare, but the front water pan could have a hole in it.
Posted on Jul 25, 2008
Intertherm electric furnace model E2EB-015HA. Upper element will come on and run continously in 20 degree temp, Lower two elements don't come on. What's up?
Sounds like one or 2 stages of the sequencer is not kicking the other elements on. -OR- the limits ie klaxon switches in series with your elements are stuck open.
Dec 08, 2013 | Heating & Cooling
Model e2eb-015ha elements cycle on and off, but blower motor never comes on;a/c side works fine
R u saying that the blower motor works for the AC but not for the heat. If thats the case then u have a t-stat or control board problem. u can jump the red white and green wire from the tstat. if that works then then tstat needs to be replaced if not the control board is the problem.
Oct 21, 2011 | Intertherm P3RA-048K Air Conditioner
Model# E2EB-015HA is blowing cold air instead of heat.
do you have a call for heat from stat. spark ign/ glow coil test glow coil ohm should have rest./ spark ign-do you have sprk try turning off power turn back on if unit fires/ a saftey has shut you down find problem im assuming you have working knowlege of systems never bypass a saftey. hope this helps
Dec 29, 2009 | Intertherm P3RA-048K Air Conditioner
I need an installation instructions for a
Hi, This is a very popular unit. Call you're local wholesale a/c parts house with all of the info on this 2 1/2 ton unit, and they can help. Have you tried going online to search for this? Would also try this. Good Luck,
Shastalaker7
Nov 12, 2009 | Intertherm P3RC-030K Air Conditioner
My Intertherm E2EB-015HA leaks and keeps shutting down
I would not blame the manufacture sound like the clowns that installed it. Tom
Jun 23, 2009 | Intertherm P3RA-048K Air Conditioner
Wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Dec 21, 2008 | Heating & Cooling
Heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Dec 10, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm heat coils won't stay off until breakers off,thermostats are off
it is the heat sequencers. it happens all the time. replace them wire by wire to keep it simple. they are located behind the metal next to the breakers they look like this: cdf7518.jpg
Oct 19, 2008 | Intertherm P3RA-024K Air Conditioner
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
310 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
