1974 FENDER TWIN REVERB HAS NRE TUBES NEW FILTER CAPS AND WAS REPAIRED BY RETIRED AUTHORIZED FENDER TECH. PROBLEM AMP HAS VETY LOW OUTPUT UNTIL YOU CRANK IT TO 8-10 THEN IT SOUNDS HORRIBLE DISTORTED AND LOW NOTES LACK DEFINITION (MUD) WHEN I PLAY AMP AT 5-6 ON MASTER AND PREAMP KNOBS IT HAS HARDLY ANY OUTPUT, PLUS TURN THE GUITAR VOLUME DOWN AND IT SOUNDS LIKE A TRANSISTOR RADIO FROM 1960. HELP TECH SAYS EVERYTHING IS OK ONE OF US IS CRAZY.
  • 122 Answers
Check the speakers try to connect another speaker.then check the output transformer and the resistances at the bottom of the 6L6 tubes.then check the bases of output tubes and the output tubes matching trimmer if your amp have it.then check change the volume pot.then check the ceramic capacitor i n the input of the last 12ax7 tube in the power amp input.
Posted on Jun 13, 2010
    Genius:
  • 1,139 Answers
Hello Ktabbott,
I am going to ask you to do a strange thing, that is check the volume pot (potentiometer), make sure it is an audio taper control and not a linear taper control. This is a common mistake, linear taper pots being used instead of audio taper pots. This is what your problem sounds like.
Thank you,
Shuttle83
Posted on Jul 22, 2008
  • 4,234 Answers
This sounds like a power supply problem. The high voltage for the tubes is not right. Either you are missing an amplification stage because this or one of the coupling caps is faulty. I'd have to see the unit itself to give you any more details.
Dan
Is there a way to make the sound of the reverb on my deville 2-12 sound better ?
modding the reverb takes some electronics experience...if you know where the reverb circuit is. all you can really do is change the input caps that make the tone bright or dull... larger uf for dull... lower cap values for bright... it's in the signal circuits... dont mess with power caps. The schematic shows op amp into the tank and out of the tank to another op amp...Output of the tank to opamp.. Id double that input cap ( 330 pf ) to see if you get more response into the opamp... then look at the circuit C17-C18/R33-R34 894cf4a0-46f7-4f21-9667-be620f05b31d.png
Jun 06, 2012 | Fender R) Hot Rod DeVille III 212 Guitar...
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
Twin tube amp. power comes on, no sound. replaced tubes, still no sound
Do you have the speakers connected properly?? If so, maybe speaker wiring needs checked.
Feb 19, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
Fender vibrolux. Very (loooud) loud hum/buzz All tubes but the 6l6's removed. History: bought this amp as a repair project. replaced all caps. originaly the amp was quiet but but had very little volume...
Here is the schematic:
http://elektrotanya.com/fender_vibrolux_6g11_schem.pdf/download.html
Check the quality of the DC bias as being free of ripple.across teh 25 mfd/50v cap filtering the bias.
If much ripple there, replace the cap. Also the .05 bypass on the swinger of the intensity control.
This should be an easy fix, but you might need an oscilloscope to diagnose it quickly... or just parallel caps across these to see if it kills the hum.
The main high voltage filter caps are also suspect as well as the bypass of power to the ealier inverter stage a 16mfd/450v
There are lethal voltages in this so use great caution when troubleshooting... the caps hold a nasty charge.
Feb 06, 2011 | Fender Custom Vibrolux Reverb Tube...
I have a brand new fender deluxe combo amp is the preamp in and out usable for an effects loop
Yes you could do that. The preamp output is just a BUFFERED output of the signal sent to the power amp. And the power amp input jack is BUFFERED before driving the power amp. These impedances are neither high or low being in the 1K to 3K ohm range.
The jacks for BOTH are mono jacks so noise pickup is possible if long cables are used. The external effects unit should be well grounded and operate off the same receptacle as your Fender for system safety. Use SHORT audio cables to minimize noise.
ALL the signal will pass through the effects unit when used this way... HOWEVER the internal reverb will still be in this path. You can kill this by turning the reverb control to zero on the Fender.
May 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Apr 24, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Loud buzzing noise when I turn amp on -won't go away
change the plugs on the chords.or both.they loose their resistance.good luck.
Feb 28, 2010 | Fender Audio Players & Recorders
Fender deluxe reverb amp keeps blowing tubes
If it's blowing fuses. It probably has a bad output tube.
If it's blowing tubes. It may have a cracked tube socket.  Also may need to be biased by a tech.
Aug 20, 2008 | Audio Players & Recorders
I have a Fender tube amp The Twinn. 4 6l6 2 12at7 and 4 12ax7. Mu reverb is dead and I here some strange oscillation. I suspect the 12at7 in reverb and one 12ax7 Both microphonic and very dem fil. ...
Hi ohmytom
Yes, they could be causing the problem.The filaments are a little hard to see sometimes, you will always get a little microphonic activity about preamp tubes. It may also have failing capacitors depending on how old it is. Is it a "Twin Reverb". Let me know the exact model and we can be a little more specific of the problem and solution. Cheers
regards
robotek
Jul 14, 2008 | Audio Players & Recorders
Fender reverb mod both channels
Go to http://www.silvertoneamps.com/micKfender/Fender-Reverb-Both-Channels.html
there is info on this mod. heed the warnings of hot rod activities!!
There is a solution to your misguided nods you mentioned earlier.
Dec 16, 2007 | JBL Control 23 Speaker
328 people viewed this question
 Grubhead
Grubhead
