Question about Bosch Nexxt WTMC 3300 Electric Dryer
Dryer continues to spin periodically after the clothes are dry - doesn't shut off completely
I think it may be the wrinkle gard that keeps the dryer running once every hour if you do not shut the dryer off imediately after the clothes are dry. I have been told there is a way to shut this option off but I can't find it in the manual that accompanied my dryer. Could you please help me and give me directions to do this.
  • 130 Answers
Yvonne sorry but that isn't a feature you are able to turn off. It happens that the buzzer goes off as well that people don't like. Only the top of the line model allows the buzzer to be turned off. The wrinkle guard is just that, to help prevent wrinkles.
Posted on Aug 09, 2008
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
After dryer shuts off, timer continues to run. Kenmore model #110.86181810, part # I think is 692032 and sears says it is no longer in stock. Anyone still have one?
I assume you're talking about the buzzer. Many high end dryers do that until you remove the clothes. heated clothes can set wrinkles if kept in the same position for a long time. it's a feature, not a problem, unless it keeps buzzing after you remove the dried clothes!
Apr 15, 2013 | Kenmore Dryers
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
My dryer will not shut down or advance when it is in the Automatic Perm. Press mode. Diagnosed with faulty timer, replaced yesterday for ~$300 and the dryer ran all night long. Is there a "dryness sensor"...
I have found that the permanent press cycle will continue to roll the clothes around on a rest and dry schedule until you take the clothes out and manually shut off the dryer. The idea seems to be to keep the clothes from wrinkling when sitting in a still dryer. I think that this is the way it was meant to work, but I am no expert, just another owner of a Fisher Paykel dryer.
Oct 15, 2010 | Fisher and Paykel DE06 Electric Dryer
My dryer panel is turning on by itself. when I shut it off, it turns back on after a while. A load of clothes is drying, and the dryer keeps making a beeping sound every now and again. It seems to be...
Many of your better dryers have an anti-wrinkle function. When a load is complete if you don't take care of it, every little while the dryer will turn on for a few minutes to fluff the clothes and beep to remind you.
May 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer won't shut off automatically
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
May 09, 2010 | Maytag MED5800TW Electric Dryer
My clothes is wrinkles by my front loader washer
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My LG dryer shuts itself off during the normal cycle and a dotted
OK, here's what it sounds like to me: The line going around the display should only be seen if you selected "Wrinkel Care" function for that cycle (and with the freshen up cycle, I beleive). With that option in use, after the dryer shuts off, if you do not open the door or turn off power to the dryer the dryer will display the moving rectangular segments and every 6 minutes the dryer will turn itself on and tumble for 10 seconds with no heat (to keep clothes fluffed up and prevent wrinkles from setting in) and will continue this cycle for up to three hours. The "Freshen Up" is the steam cycle used to remove wrinkles from 1 to 5 garments, like things that were all wrinkled up in your suitcase. Try drying with a normal or permanent press cycle, or a timed cycle. If you have additional questions or concerns, let me know.
Dec 06, 2008 | LG WM2077CW Laundry XL Front Load...
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
521 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
