U87 grill i need a new grill for the u87 where can i get it for chep..or used
My u87 cuts out when you get to close but comes back on in 2 secs seems to be wind pressure from singing. many thanks Graham
problem is a dirty capsule caused when fogged with humidity from breath it shorts out temporarily. it maybe possible to have it professionally cleaned but may need to be replaced. DO NOT USE FOAM POP FILTERS. Spend the money on a metal one. back off if you wanna save some loot.
May 18, 2011 | Neumann U87 Professional Microphone
My U87 microphone won't power up...no signal. does anyone know why this may be happening?
Was it working fine before it stopped powering up? The U87 is a condenser microphone so maybe the reason it is not powering up is because the phantom power on your interface was not turned on. Plug the U87 into your preamp and then switch on the phantom power (48V) to get it powered up. If that doesn't help, there must be an internal fault within the microphone or in your preamp.
Mar 02, 2011 | Neumann U87 Professional Microphone
Game acceptance
its not called chepping its called cfw you download it of the net or use a pandora batery and a magic memory stick
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
Can't get new universal remote to work with bose av28
How old is your remote? My bose remote was prone to breaking. The RF antenna inside the remote housing tends to break away from the electronics board. I have re-soldered mine on a number of occasions. This is not a complex fix for someone who can use a soldering iron. After it happened the third time, I installed padding around the antenna so that it couldn't shake around and break free. That seems to be working so far. Hope this helps.
Dec 10, 2009 | Bose Lifestyle 28 System
Hello i got this bushnell 565 tellescope from a garage sale but it is missing parts
http://www.bushnell.com/customer_service/manuals/telescopes/78-9565_Voyager.pdf
Start here with this parts diagram. I am searching for a few missing parts myself and will let you know if i find a source for them.
Oct 22, 2008 | Optics
Neuman u87 strange sounds
Might be humidity. It's a condenser microphone and moisture will cause the hiss. I'm in a humid area with a couple of 87s, and that happens regularly.  Put it in a closed bag or container with dessicant and it will dry out the diaphragm. Alternatively, shine a lamp with an incandescent bulb on it to dry it up.
Oct 01, 2008 | Audio Players & Recorders
Removingand replacing screens on Akai-PT5499HD
HELLO. WELL YOU WILL NEED TO TAKE OFF THESPEAKERS GRILL'S ON THE FRONT OF THE SET .UNDER THEM YOU WILL FIND SCREW'S THAT HOLD IT ON . THE FRONT OF THE SCREEN IS THE FRENSEL & THE BACK SID OF IT IS THE LENTICULAR. LENZ. WHEN U CLEAN THEM USE ONLY SOAP AND WATER AND A VERRY SOFT CLOTH. NOTHING ELSE. OK AND FOR THE CRACK IN THE FRONT . YOU CAN USE ELMER'S GLUE . THE WHITE GLUE. IT DRY'S CLEAR. BUT MOST PEOPLE FIND A NEW ONE . ON LINE CHEP. WELL HOPE THIS HELP'S YOU.
"GOOD LUCK"
Jul 20, 2008 | Akai PTH5498 54" Rear Projection...
Neumann U87 no signal
Who serviced the mic? Send the mic to Tracy Korby or Klaus Heyne.
The capsule can get dirty and then behave in the way that you describe. It is possible that a simple cleaning by a professional will bring the mic up to spec.
Apr 06, 2008 | Neumann U87 Professional Microphone
43 people viewed this question
 Grubhead
Grubhead
