We have a Mitsubishi DLP telvision model wd52525 the light beneath the timer keeps blinking, and I can't get the television to turn on. I have unplugged and replugged it back on and have pressed the "reset" button and nothing has worked. Please help.
  • 8,617 Answers
Press the input and menu buttons on the front of the set and see if a two dgit error code will blink. It sounds like a 3 4 code.
Posted on Jul 22, 2008
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
AFTER A POWER FAILURE GREEN TIMER LIGHT WILL NOT STOP BLINKING. HAVE TRIED TO RESET TIMER, UNPLUGGED POWER SOURCE. THIS IS A MITSUBISHI DLP WD52525
The Capacitors on the DM board need replaceing. The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the capacitors and the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Blinking timer Light (Green)
Thats a common problem caused by defective capacitors on the DM PWB which prevent the set from booting up. The V26 DLP DM kit at the following link will usually repair that issue and it comes with step by step instructions on how to do the repair. Look under the repair kit category.
http://servicemanuals.vstore.ca/
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
No picture no sound
it sounds like the chassis has gone bad. check out www.tv-techs.com
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I need the schematic for mitsubishi television wd52525
go to www.blinking-green-light-of-death.com
it shows available.
Nov 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green timer light keeps blinking
Ross,
Please email me at experttv@comcast.net So i can help you.
Thank you,
Tim Nolan
Oct 14, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 29, 2008 | Mitsubishi WD62628 62" Projection HDTV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
