Question about Linksys Wireless-G Broadband Router
Linsky wireless connection
I moved and cannot find the CD to my Linsky's Wireless Router. Is there a way to set or reset it so no one uses it illegally? My router was shut down due by my cable company because someone tapped in and downloaded music.
  • 298 Answers
Yes, you can still manually configure the router to setup a wireless security so that no one can use the wireless illegally and download files. What is the model no. of your router?
Posted on Jul 22, 2008
How do I set up a password for my Linsky
Open the setup page of the router and change the wireless settings manually.
Connect the computer to the router with the Ethernet cable and open the setup page using 192.168.1.1 . Go to Wireless tab and change the wireless network key settings.
Nov 25, 2011 | Linksys Wireless-G Broadband Router
Linsky router has been connected for a year and working fine but within the past 24 hours even though the signal is strong for connection it will not permit us to go wireless on the laptop or son's XBOX...
can you access the Linksys page while on wireless even if it gives you page cannot be displayed error when you browse?
try to do a hard reset on the router and reconfigure your wireless connection. just press the reset button for 10 seconds to reset it properly.
Jan 27, 2011 | Linksys Wireless-G Broadband Router
I have a linsky wireless G 2.4 Ghz 54Mbps (model WRT 54G) I have the cd, but I do not have the password. I am not sure if this is the reason, I can't set up my network. How do I get another password
Linksys WL router always has default password "admin" you will have to reset router to factory defaults by plugging Pin in to Tiny Hole on Router back side for 5 seconds. and then login by default ID "admin" and password "admin" to configure router again. [Remove Inverted Commms from User name password while entering
Mar 09, 2010 | Linksys Wireless-G Broadband Router
Secured used router
The following actions will clear all settings and restore them to factory defaults.......
On the back of the linksys there is a reset button. hold that button down for 30 seconds.
Once this is completed you can access the router by connecting it to a computer. Open a browser and type http://192.168.1.1
At the log in leave the user blank and enter admin for the password.
Best of Luck
Jan 18, 2010 | Linksys Wireless-G Broadband Router
My linsky connection was canceled and i dont have the disk
Log on to your linksys router page and reset the security key to what ever you want.Just open internet explore and type 192.168.1.1 and when the sign in box appears and if you didn't set up a password Just type Admin for the user name and Admin for the password.
Please take time to rate this a fixya
May 11, 2009 | Linksys WRT160N Wireless Router
Login on to linsky
Under this condition you should connect the linksys router physically by LAN cable and that try to get connected with and reconfigure it properly as per your requirement. If still unable to solve the problem than kindly reset the unit to factory default by pressing the reset button.and that try to get connected with and reconfigure it properly as per your requirement.
Dec 23, 2008 | Linksys Wireless-G Broadband Router
I have the 4 port Linsky Router.I have a Sony laptop connected to a Sony wireless routerI also have a movie download box. When I connect both to the modem separetely,bolth the laptop and the mvie download...
this is because your wireless router is a router, and your linksys is also a router. Both are attempting to do routing, and they're colliding with each other.
Go into your linksys router's settings, and set it's IP address to have the SAME subnet mask as your wireless router, (The third number in the ip address has to be the same)
e.g. if your wireless router is 192.168.0.1, make sure your linksys is 192.168.0.2
if your wireless router is 192.168.2.1, make sure your linksys is 192.168.2.2
After that, turn OFF the dhcp server on your linksys router (do this in the linksys config page).
After that, plug the LAN port of your linksys to the LAN port of your wireless router.
Your linksys will now be acting like a "Switch" which is an extension of your network. Voila!
Dec 06, 2008 | Computers & Internet
Wireless connection
You need to edit you're router's wireless settings, maybe there is a conflicting default network w/in you're range. Make sure you change the SSID (wireless name) to a unique name, the channel I advise you to set it to CH11, and enable wireless security as well, you can go for WPA-Personal it will be supported by XP and it's a good encryption method. And try removing all the network's listed on the "preferred networks list" on windows to make sure there won't be any conflicting wireless profile.
Aug 19, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linsky password
If you're after the default userR/password to log in to the admin-intaserface on the router it's usually ussername=root and password=admin
If it's the wep-key it's asking for there are software that can fetch this from your computer, but it's probably just as quick and easy to change the wep-key in the router and set up your writeless computers with that key.
Nov 27, 2007 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
