Bowin sle 2 Heater Not igniting. Power on and gas connected. The clicker is sparking but will not light the heater. Gas is flowing, as I can smell the gas.
fridgetech
  • 473 Answers
SOURCE: how to locate and remove oven ignitor
Will need to remove the panel at the bottom, inside of the oven.  Some have another panel under that, yours may not, to remove.  The ignitor is under that in the back middle.  Should be screws that mount the ignitor to the burner.  You may be able to remove the bottom drawer and unplug the ignitor underneath the oven and remove the ignitor.  If not you can cut the wires on the old ignitor and splice in the new one using ceramic wire nuts.  Let me know if this helps.
Posted on Oct 14, 2007
SOURCE: Pool Heater
You can light the pilot with a B.B.Q. lighter.
Nottoohandy. Backwash you filter, make sure it's really clean. If that doesn't work it could be the pressure switch. You can by-pass the switch with a piece of wire to see if it fires up. If it does, it's the switch. There is a picture of the switch in the manual.
C
Posted on May 26, 2008
SOURCE: Stadt Ducted Heater ignition problems
Could be a number of things
Sounds like it the gas valve. If the gas Valve isn't opening or is burnt out then no gas will flow through it.
Also it the pilot is blocked then you wont get and gas coming through to light it up.
I am forever replacing gas valves on the buffalo series units and have found this to be quite a common problem on older units.
Posted on Aug 21, 2008
SOURCE: gas heater not working...no flow
gas heater is not working;
flow gas thru..YES; ain't flame in all unit made it by carrier
Posted on Oct 17, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: heater won't ignite when heater is turn on.
See if the spark will arc across the area where the pilot flame is. It should cross the flame. Adjust the spark if possible.
Posted on Nov 12, 2008
VERY GOOD "spark" HOOKED UP YOU CAN SMELL THE GAS WHEN YOU HOLD THE BUTTON IN IT WILL IGNITE THE GAS WHEN THE FAN OFF BUT DOES NOT
Possible weak gas flow to igniter may require adjustment, have a qualified gas technician check it.
press the helpful button
Jan 08, 2016 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My hayward swimpro abg100 powers on but nothing happens. I can hear a buzz coming from it but it does not ignite or anything. What can I do?
Warranty status? Probably gas control valve and its connections to the "buzz" ignitor system. Gas is not a DIY thing!
Jun 07, 2015 | Hayward Pool & Spa
Laars Lite 2
If the heater is "acting normal" with no failure codes and you smell gas, then I would bet it's the igniter. The fact that you smell gas indicates the heater does not have a failure in any of the safety circuits and wants to fire. It is just missing an ignition source or the gas you smell is not making it to the proper place to be ignited. Given these two options it is most often the igniter. Replacing the igniter is not difficult but it is a VERY delicate part and experience in handling it is benificial.
Apr 14, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater
It sounds like the ignitor is not working, Since the heater is not detecting a flame it goes to lockout. Check the ignitor wiring to see if it is in good shape. Sometimes the connection where the wire (from the IID) connects to the ignitor gets corroded.
It could also be the IID which makes sure the safety loop is complete before calling for heat and sending current to the ignitor. Good luck with it.
Jan 11, 2014 | Mr. Heater Natural Gas Garage Heater -...
I can smell gas but heater will not ignite. Display shows that the heat is on. Thanks!
First of all, be careful while looking into the system when the gas comes on because it could unexpectedly ignite and burn you.
You listed this question in the Jandy Lite 2 Natural Gas Pilot Light Heater. If your heater is a pilot light heater then the pilot light needs to be lit so when the gas comes on it will ignite.
If your unit contains a thermal ignitor it should glow brightly when the gas starts. If it is glowing then it is probably not glowing brightly enough or not in the right place and therefore needs to be either replaced or repositioned. If it is not glowing then you should measure the voltage using a volt/ohm meter going to the ignitor. If it reads about 115 VAC then the ignitor is broken and needs to be replaced. If it reads much lower voltage then the board that supplies power to it probably has a problem on it. It may be a defective relay, bad solder joint or some other problem. I would first re-solder the relay connections to the board and see if that fixes it. Otherwise the board will need to be replaced.
If the unit has a spark ignitor and you hear a spark sound it may be too low power or the spark probe might be in the wrong place and therefore not delivering the spark to the fuel air mixture. If you don't hear the spark then you may have a bad relay or bad solder joint to it.
Please let me know how this works out. Thank you.
Sep 03, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
I have an AIM 3 Panel Gas Heater. I have just purchased a 9kg gas, connected everything as I normally did (last year), however the gas is not flowing through as it should. There is an ignition spark, but...
More than likely, there is air in the line from the gas bottle to the heater. Purging the air, by holding the heater's control knob down while in the Pilot position, until you smell gas, will solve the problem. This may take several minutes, so be patient. Once you smell gas, release the control knob and wait 5 minutes before attempting to light the pilot.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Heating & Cooling
When the heater is on there is a smell from the gas. Is this dangerous? What causes the smell?
How strong is the smell?
The smell is usually caused because the heater to turn on the flame has to emit a bit of gas first, and then a spark is made by the heater to make the flame burn, which in turn causes the rest of the flame in the heater to heat up the water.
If it is a constant smell, then I suggest you immediately turn off the heater and stop gas flow to the heater (should have a valve close by) and call the numbers that are shown on the unit. They will help you from there.
Jun 19, 2011 | Salton Clarity
Have 2 heaters 1st heater will not light, has gas
sometimes you need to hold down the button for 5 to 10 seconds while the heater heats up,, as soon as it gets to temperature then it should stay on with no problem.
as far as the one that is not lighting -- all I can thing of is that the igniter is not close enough to the fuel exit area ( ? ),, with the power off - ( un-plugged ) look inside as you press the igniter and see if you can see the spark arch. -- also, if this is a new heater there is a chance that there might be something wrong with the regulator and it is either getting to much or not enough gas.
c...
Dec 31, 2010 | Scheu (85-FAC) Heater
My heater will not light and electronic ignighter just continually sparks but burners do not light up? I've checked gas, etc but just won't light. Any suggestions? Do burners need replacing? Heater is 8yrs...
Do you physically see the spark or are you just hearing it. You can also take the igniter wire off of the control module and disconnect the pilot gas tubing from the gas valve. Turn the heater on and wait to see if you hear and smell gas coming out of the gas valve. If there is no gas check for 24v at the PV connection on the module. If there is voltage the problem is the gas valve. If no voltage the problem is the ignition module. If there is gas I would replace the pilot and gas tubing.
Santa Clarita Pool Heater Repair
Apr 19, 2010 | Pentair 250k Minimax Ch Ng Mv Heater
Laars lite 2 Spark egnighter will not spark
turn power off first. I would disconnect igniter wire which will be a thick orange wire that comes off of ignition module if it is spark. once you have that the end will look like a spark plug wire take shield away from metal then hold orange wire in hand close but not touching metal turn power on and it will take a couple of minutes before it should start sparking. If you don't see a spark then it is most likely the ignition module. There should be a red light on ignition module that will blink to tell you what the failure is if is is a newer on. When you turn power on to laars light 2 the inducer motor should come on then a pressure switch should send 24volt to gas valve for pilot to lite.Can you smell gas at all when laars should be igniting. If you have any questions fell free to email me back
May 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
