Philips lc171w03-c4 backlight broken - Televison & Video
Dear Sir We are looking for 100pcs of LC171W03-C4. Please kindly send us a quotation as soon as possible. Best Regards Jung-hyun Yeo
Posted on Jul 30, 2009
PHILIPS TV 42PFL3604/12 not working. Power Led lights up white but no backlight working and no picture
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 25, 2015 | Philips 42PFL5332D 42 in. LCD Television
Philips tv black screen
Check and replace the back-light inverter board. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 28, 2014 | Philips Televison & Video
Speedometer in 1992 Corvette quit
Do you have a fuse for "gauges" and does it have power ?
Feb 07, 2013 | 1992 Chevrolet Corvette C4
Philips 220ws backlight
This is a common problem and the backlight needs to be replaced.
Jan 21, 2013 | Philips 220WS
The screen of my LCD 37PF5321 is broken and no video is now available. Where can I order a new or even refurbished screen?
if you hurry you can order one off ebay its a olevia but they use the same screen 220724844497 which is an lg philips panel. Before doing that check if your backlight inverter is defective. A more common problem with this tv is blue screen from tcon board failure which is quite easy to fix.
Jan 18, 2011 | Philips 37PF5321 37 in. HD-Ready LCD...
My philips lcd tv has sound but no picture what is
change the backlight (cold cathode light) on your monitor.. If you are able to open the back of your lcd monitor carefully, the backlights are located at the upper and the lower part of the edge .. replace it with conventional cold cathode lights(protective tube was removed)... there are also instances that backlight was good but the ballast transformer is burnt. Replace the ballast. Its very cheap to replace that.
May 18, 2010 | Philips 42PFL7432D 42 in. LCD Television
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips GoGear HDD086/05 backlight will not stay on
go to the settings on the mp3, go to backlight and set light to "always on".
May 20, 2009 | Philips GOGEAR SA6045 MP3 Player
Televison & Video Logo
694 people viewed this question
Top Televison & Video Experts
Electro Med Services...
