Question about Westinghouse LTV-19W3 19 in. LCD Television
No sound the sound on my westinghouse tv has failed. Is there warranty service available? how do i find it?
  • Anonymous Jul 29, 2008
    No sound
The sound on my son's was terrible, so he went and bought a pair of speakers, like for a computer, and now it's okay.
Posted on Aug 19, 2008
I have Westinghouse tv 55 inches less year old and some times it turns black but the sound still work I should turn it off then on and it'll be fine may be I use it for a whole day nothing came up some...
The Westinghouse warranty period is 1 year from date of purchase. You'll need your receipt or some way to validate your purchase date.
Contact Westinghouse directly here: Warranty WE
Feb 01, 2018 | Westinghouse Televison & Video
Sound not working on my Westinghouse TV
OPTIONS
, first try to reset your TV. Disconnect it from AC power, then press and hold the power button on the TV, and not the remote, for 10 seconds. After another minute, plug the set back in and press power once. Then try the other sound out from your TV to a set of speakers etc. If that works, you know that your internal speakers are not working. If it does, it is most likely that the audio IC that drives the internal speakers has failed. It is common in these sets as they use inexpensive low powered amplifier IC's that heat up and fail. You can try to replace the IC, if you have the right tools and experience, or replace the mainboard, part number 1AA4B10N260A0. The IC itself is LV4906 and the mainboard is available at places like this. Hope this helps, good luck
Jan 03, 2018 | Westinghouse Televison & Video
Westinghouse legacy firmware for old 47" LCD TV. Manufacturer website "not available".
I don't think the firware to this TV is available online or by any other means, if it is out of production. Contact the authorized service centre for Westinghouse. They can help you.
Gopakumar Gopalan Google
Dec 25, 2014 | Westinghouse TX-47F430S 47 in. LCD TV
Westinghouse tv has no sound, i do have picture (sometimes), however when I power the tv up, sometimes the picture comes up sometimes not
If you have the TV in a heavy traffic area, use a can of compressed air to carefully dust out the insides through the vents. Excessive dust build up can cause intermittent problems like this.
Most of the potential problems that would affect both sound and video are on the integrated circuit boards, and can only be serviced by the manufacturer.
Check if your TV is under warranty -- if so, I would call Westinghouse to request service.
http://westinghousedigital.com/support/warranty/
May 06, 2011 | Televison & Video
My westinghouse monitor suddendly went Black.
Hello, normally you have a one year parts and labor warranty from the manufacturer, if you are still with in that time frame you should call the Westinghouse customer service line at 1800-701-0680. If you are not with in warranty the problem sounds like it might be the power board that messed up. What you can do is email parts@wde.com, let them know the model#, serial#, and the problem you are having and they will let you know the price and availability of the part you will need to purchase.
Nov 06, 2009 | Westinghouse LCM-19v1 Monitor
Westinghouse 42' tv working fine this morning, got home from work this evening turned tv on picture come on for about 4 seconds than blank screen still had sound pressed menu botton still blank screen...
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 01, 2009 | Westinghouse Televison & Video
Service location for westinghouse lcd in brooklyn ?
Dont worry about the location, you dont need to take your TV to a repair center, just call westinghouse and let them know about your TV issue and they must send a tech over your place or replace it for no cost.
Jun 02, 2009 | Televison & Video
Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
May 18, 2009 | Westinghouse SK-32H240S Television
Westinghouse 26 power problem
Try call Westingtonhouse for service at this number. By Phone:
For help with the following: • Installation or operation of your Westinghouse Digital LCD products • Warranty assistance • Service to obtain service an RMA (Return Merchandise Authorization) is needed • Refurbished product service request Our service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
Note regarding LCD Drivers
Since Westinghouse LCD TVs and Monitors are plug-and-play devices, they do not require any drivers. If your computer is unable to display at the recommended resolution, please check your graphics card to see if it supports the recommended resolution. You can periodically check the graphics card manufacturer's website for any updates. I hope this helps you with your problem.
Jan 09, 2009 | TruTech PLV16320 Television
Extended warranty
Hi deputy bill,
To find out if you purchased an extended warranty, contact Westinghouse at (866) 287-5555. They may also be able to provide support for the problem you are reporting.
Keep in mind that retailers also offer extended warranties or service plans. If Westinghouse advises you that you did not purchase an extended warranty, check with the retailer from whom you made the purchase to see if you may have purchased a plan from the retailer.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
Westinghouse LTV-19W3 19 in. LCD Television Logo
55 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
