Question about Admiral AW22 Top Load Washer
Dirt like pebbles left in the bottom of the washer after the cycle is complete
I have an Admiral washer and after a cycle there are dirt like pebbles left in the washer. I am assuming dirt is trapped under the aggitator? How do I remove the aggitator to clean under it? And could there be another problem/solution?
Thanks for the help
C
Take the fabric softener cap off just pull. then look down the middle there will be a bolt 10 mm loosen it and pull the agitater
Posted on Aug 01, 2008
Wa52j8700a dirt remains bottom of washer
I would try to run an empty washer through about 4 or 5 rinse cycles and see it the machine will clean itself.
I would also carefully wipe it out after each complete cycle.
God bless your efforts.
Feb 29, 2016 | Washing Machines
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
Dirt left in tub
Contact GE or Sears service...doesn't sound like the unit is cycling properly.
Nov 02, 2017 | Maytag Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Admiral aav7000aww water slowly leaks into tub when machine is off
You need to replace the water valve. here is a link to the part. Here is a video to show you how to replace it.
Nov 28, 2010 | Admiral AW22 Top Load Washer
Washer gets to 20 min left in rinse cycle recuriculation pump comes on and off anything from 5 seconds to 2 min control countdown stays at 20 min for over 20 min? whirlpool calipso
usually problem with digital washing machine is on the program module, exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hoseline.
Jul 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Residue is left behind after cycle is complete. Dishes looks dirt
if dirt is not being washed away it is most likely you have a clogged screen before the waste tube. Depending on the model. Dismantling the dishwasher takes place inside it and under it where the motor is located.
Mar 13, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Water left in bottom of machine when cycle finished.
you must check filter,it is full of dirt.
it must be on front side,down left or right corner,
May 21, 2009 | Dishwashers
Loose dirt and a lot of watter won't drain when cycle completed
One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it not to drain. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine especially in a Bosch. This should take care of your problem.
Apr 10, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
Admiral AW22 Top Load Washer Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
