I cannot remove "Shield Deluxe 8" from my P.C.
  • 385 Answers
Try turning off the program. In the right hand bottom of the screen, right click on the D icon and click on exit. This will disable the program. Then go to the Control Panel, add/remove programs and select the shield deluxe program and uninstall it.
If you still have problems, let me know..
Thanks,
Lolita
Posted on Jul 22, 2008
Can't install expat shield on my windows 8 computer
Is it compatible? 32 or 64bit? Download the program to a folder and modify the compatibility, if you haven't already. It states it's compatible with Win 8. http://expat-shield.en.lo4d.com/ Here's a compatibility procedure : http://www.eightforums.com/tutorials/6832-compatibility-mode-use-windows-8-a.html
Mar 02, 2013 | AnchorFree Expat Shield
Tip
How do you make a Bluetooth Antenna?
<p>"Everything is better with Bluetooth" is an adage that was popularized by the television program "The Big Bang Theory. It's hard to argue with that. Bluetooth is a fast and secure way to transfer digital information. While it is useful can extend the range a Bluetooth connection, making your own antenna to make technology more valuable. <br /> <p><br /> <p>1. Pry apart the case with a Bluetooth screwdriver. Remove the electronics module. <br /> <p><br /> <p>2. Heat the existing antenna cable with a soldering iron and pull it free from the oscillator. <br /> <p><br /> <p>3. Remove the excess solder the electronics module using a disordering braid. <br /> <p><br /> <p>4. Remove the outer insulation of the new antenna cable, and cut the outer shield of the coax to the wire strippers. Add a little solder to the shield for the more solid. <br /> <p><br /> <p>5. Exposing the central thread of removing the cable from 1 / 2 inches. Leave a bit of plastic between the wire and shield. <br /> <p><br /> <p>6. Slide the wire through the hole and bend it at right angles. The shield should be established by the turtle. <br /> <p><br /> <p>7. Protect the solder and pad together. Turn the plate over the center wire and solder in the hole. Remove any excess wire with wire cutters. <br /> <p><br /> <p>8. Clip the excess wire stabbing through the hole and insert the module in the case and assemble the two halves. Use tie-tape, glue or tape to hold it together when necessary. <br /> <p><br /> <p>9. Insert the module on the subject and put things back. Use clamps to hold it together. <br />
on Jun 26, 2011 | Computers & Internet
Removing starter nissan pick up 4 cylinder engine
Okay , i will give you step by step, the book calls for .9 for time.
1) First remove the front right tire.
2) Remove neg battery terminal.
3) Remove starter wiring.
4) Remove the right front splash shield.
5) Remove the exhaust manifold heat shield.
6) Remove the exhaust manifold.
7) Remove the oil filter.
8) Remove the oil sender connector.
9) Remove the starter bolts and remove starter from cylinder head side.
Hope this helps, let me know how it goes, good day.
Dec 24, 2012 | 1991 Nissan Pickup
My husband and I are trying to get to our thermostat to change in my 2002 rendezvous, but there is a metal pipe in the way that we can't figure out how to remove. just behind the pipe, is a metal plate...
Hello vocalviixen,
The pipe that you referred to is the exhaust crossover pipe. Below I've included removal and installation instructions.
Also, the procedure for bleeding the coolant system is critical; if you need those instructions please post the question.
REMOVAL PROCEDURE
1. Disconnect the battery ground (negative) cable.
2. Remove the throttle body air inlet duct.
3. Drain the coolant from the cooling system.
4. Remove the inlet radiator hose from the engine.
5. Remove the thermostat bypass pipe.
6. Remove the exhaust crossover heat shield bolts.
7. Remove the exhaust crossover heat shield.
8. Remove the exhaust crossover pipe studs/nuts.
9. Remove the exhaust crossover pipe.
INSTALLATION PROCEDURE
1. Install the exhaust crossover pipe.
2. Install the exhaust crossover pipe studs/nuts.
3. Tighten the exhaust crossover pipe studs/nuts to 18 lb ft.
4. Install the exhaust crossover heat shield.
5. Install the exhaust crossover heat shield bolts.
6. Tighten the exhaust crossover heat shield bolts to 89 lb in.
7. Install the thermostat bypass pipe.
8. Install the inlet radiator hose to the engine.
9. Fill the cooling system with engine coolant.
10. Install the throttle body air inlet duct.
11. Connect the battery ground (negative) cable.
Regards,
netvan
Mar 14, 2011 | 2002 Buick Rendezvous
What do i do to remove "security shield" virus?
Security Shield is a bad virus that won't let you do anything on the computer, so follow the instructions on this link to remove it.
Dec 27, 2010 | Microsoft Windows XP Home Edition
Security shield license key?
Security Shield is a rogue security software, a form of computer malware that deceives or misleads users into paying for the fake or simulated removal of malware, or that installs other malware. So you really don't want it on your computer. Instead of getting a license key for it, you need to remove it.
If it won't let you do anything on the computer, follow the instructions on this link to remove it. If you can install programs on your computer, follow only steps 7 and 8 from the above link to get Microsoft Security Essentials on and remove Security Shield.
Dec 23, 2010 | Microsoft Windows XP Home Edition
How to remove alternater 2005 mercury mariner 3.0 v-6
Removal and Installation
  1. CAUTION: Do not allow any metal object to come in contact with the generator housing and internal diode cooling fins. A short circuit may result and burn out the diodes. Disconnect the battery.
  2. Remove the RH intermediate axle shaft.
  3. Remove the 6 lower splash shield bolts and the 2 pin-type retainers.
    • To install, tighten to 8 Nm (71 lb-in) .
  1. NOTE: The LH lower splash shield must be removed before the RH lower splash shield. Remove the lower splash shields.
118886165
  1. Remove the nut and position the bracket and wiring harness aside.
  2. Rotate the front end accessory drive tensioner counterclockwise and position the accessory drive belt aside.
  3. Position the generator B+ protective cover aside and remove the generator B+ terminal nut.
  1. Disconnect the generator electrical connector.
  2. Remove the generator upper air duct bolt.
    • To install, tighten to 4 Nm (35 lb-in) .
  1. Loosen the 2 lower generator bolts and remove the generator upper air duct.
  2. Remove the pin-type retainer from the generator shield.
  3. Remove the bolt and the generator shield.
  1. Remove the generator stud nut.
    • To install, tighten to 47 Nm (35 lb-ft) .
  1. Remove the generator stud.
    • To install, tighten to 7 Nm (62 lb-in) .
  1. Remove the 2 generator bolts.
  1. Position the generator aside and remove the 3 generator lower air duct nuts.
  1. Remove the generator lower air duct.
  2. Rotate the generator to gain enough clearance and remove it through the opening in the fender well.
  3. If necessary, remove the 2 generator bracket bolts and the generator bracket.
  1. To install, reverse the removal procedure.
Jul 19, 2010 | 2005 Mercury Mariner
Need a diagram of the adjustment or tension bolts for installation of alternator on 1995 Ford Aerostar-4L, Front 2 wheel Drive
This is from the workshop manual, direct quote.
Generator, Aerostar
Removal
1. Disconnect battery ground cable (14301).
2. Remove snow/ice shield.
3. Remove engine air cleaner intake tube (9A624).
4. Disconnect generator wiring at the voltage regulator (VR) (10316).
5. Remove attaching nut and wire from generator (GEN) (10346) output terminal.
6. Remove wiring connector bracket.
7. Loosen the drive belt tensioner (6B209) and remove the drive belt (8620).
8. Remove generator brace (10B315) and bolt attaching generator to drive belt tensioner bracket.
9. Remove generator from the generator mounting bracket (10153).
Installation
1. Position generator on the generator mounting bracket.
2. Install the attaching bolts and tighten to 40-54 Nm (30-40 lb-ft).
3. Install the drive belt over generator pulley (10344).
4. Adjust the drive belt tensioner as outlined in Section 03-05.
5. Install wiring terminal and attaching nut on generator output terminal.
6. Install wiring connector bracket.
7. Install engine air cleaner intake tube.
8. Install snow/ice shield.
Nov 05, 2009 | 1995 Ford Aerostar
There is a black tape that seems to be unraveling from my maytag atlantis. This tape is under the top rim of the basket. Any Ideas of what this is and if it needs to be replaced. My machine is 8 years old
Looks like this is the white plastic shield gasket:
You need to remove the front panel, loosen the top panel to be able to remove the plastic shield (it's just clipped on).
Once you have the shield removed, put gasket back in place so you are back in washing business.
Good Luck!
Aug 17, 2009 | Maytag Washing Machines
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
