Question about Acer Aspire 5100 Notebook
COMPUTER PROBLEM WHAT DO YOU MEAN THE ENTIRE SYSTEM ARE YOU TALKING ABOUT THE RECOVERY DISC I DON'T HAVE ONE HOW CAN I GET ONE. IM NOT ABLE TO GET TO VISTA TO DO RESTORE. IT JUST SHOWS SET UP AND IT SHOW ALL THE SETTING ON THE COMPUTER. IS MY COMPUTER STILL GOOD OR IS IT SHOT
  • 1 more comment
  • dherrera Jul 23, 2008
    YOU SAY IF IT DOESN'T WORK I MAY HAVE CRASHED THE DRIVE HOW CAN I FIX THE DRIVE
    HOW MUCH DO YOU THINK IT WOULD COST IF I TOOK IT TO BEST BUY TO GET FIXED
    WHAT ARE MY CHANCES THAT THE DRIVE NEEDS TO BE REPLACED? IM ABLE TO GET TO THE ACER SCREEN WHERE IT SAYS DELETE ENTER SETUP AND F12 BOOT MENU , IS GOING TO START BUT THEN IT GOES TO A SCREEN AND SAYS VERIFYING DMI POOL DATA .....UPDATE SUCCESS DISC READ ERROR OCCURRED PRESS CONT ALT DELETE TO RESTART I DID THAT AND I STILL GOES TO THAT SAME SCREEN
    IM ABLE TO GET INTO ENTER SETUP AND IT SAYS UNDER PRODUCT INFO IT SHOW INFO ABOUT MY COMPUTER
    Genius:
  • 2,028 Answers
You're computer is still good and will work fine after an operating system reload. You can order a set of recovery discs directly from Acer, or you can purchase an operating system disc from Walmart or Bestbuy, either way will work. Keep in mind that if you order recovery discs from Acer that the operating system and the drivers for your machine will be included. If you just purchase an operating system disc, then you will have to go to Acer's support site and down load any drivers that you need after the install. Also, check in the set up to see if the machine is still recognizing the hard drive. If it doesn't, you may have crashed the drive during the interruption.
Posted on Jul 22, 2008
  • Ryan Rogers
    Ryan Rogers Jul 23, 2008
    Crashed means failed, and the only way to fix the drive is replacement. Bestbuy is very expensive. To have them reload the system I believe they start at around $160, and that's if you don't have to purchase any hardware, ie... hard drive. Find a small computer shop in your area, they will treat you better and have a much better price.
System disks startup
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Nov 12, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
Kenapa pada saat penginstalan laptop muncul tulisan BOOTMGR is compressed..?
google translate
why at the time of installation the laptop it says BOOTMGR is compressed
How to Create a Windows 7 System Repair Disc:
or
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
bootrec.exe /fixmbr
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
hope this helps
Aug 09, 2012 | Computers & Internet
I got a toshiba satellite pro a100 laptop (psaace- 007002en) second hand and it still has lots of the previous owners files on so I would like to restore it to factory settings but i don't have the...
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 20, 2011 | Computers & Internet
I want to reset it
@lslchrisorei
Toshiba laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default (if that's what you mean by "I want to reset it". The hotkey for the recovery is the 0 key (don't use the key on the numpad). To activate it, you need to turn the computer off, then you need to hold the 0 key then turn the computer back ON. If you hear a continuous beep, you can let go of the key and It will then say "Windows is loading files" and will proceed with System Recovery. If this doesn't work, that means that this computer doesn't have the hidden partition for you to restore the unit to factory defaults (either it's faulty or it's not there) and you need to order the recovery discs from Toshiba at 1-800-457-7777 (for US) and for Canada, it's 1-800-663-0378.
If you're still under warranty, they'll give it to you for free.
Cheers
Sep 05, 2011 | Toshiba Satellite L305D-S5874 Laptop
I have 2 problems. My Acer Aspire 560z keyboard types garbage for some reason, so I am using an external KB. Then, I want to restore the laptop to factory settings, but the cd's are lost. I don't...
Keyboard - Do you have the NumLock on?
From the ACER support site:
To start the system recovery:
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  6. The computer will boot from the Acer Recovery Media
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Aug 12, 2011 | Acer Aspire 5610 Notebook
My toshiba a205 s4607 is stuck at the welcome screen.. i tried pressing f12 but nothing happens. when i press f2 it just says please wait and never works. i dont know whats wrong. i want to reformat it but...
I don't think it is your hard drive but here is what you could do:
Press F8 at start up to enter start options, choose safe mode with networking or last known good configuration.
Use the built in system recovery, press F11 or F12 at start up to enter recovery partition.
Use a set of recovery disc to do a system repair or to install new original operating system.
Order the recovery disc set from the website by model and serial number.
PCHELPSTER007 from youtube
Jun 25, 2011 | Toshiba Satellite A205-S4607 Notebook PC
Free download full system recovery of windows 7 home premium
Hi ,
There is no need to download anything but you can create an image of your entire system + a System Repair Disc .
Go to Start and type " back up " in the search bar . Now select " back up your computer " and click on " create a system image " in the next window and follow instructions . You' ll need an external HDD to transfer the image to it .
At the end of the procees , Windows will ask you if you want to create a System Repair Disc . Insert a cdrom ( it's sufficient , you don't need a dvd ) in your drive and click on " yes " .
In case of a later issue , you just need to load the repair disc and your system will be fully restored to the date of the image creation . So , you need to repeat the operation from time to time .
Best regards ,
fanaudi .
Apr 23, 2011 | Microsoft Windows 7 Home Premium 64BIT...
How do I reset the tower of a dell computer
If you are talking about reseting and clearing the cmos, then take the door panel off fromt he computer, locate the motherboard and there should be a battery size of a nickel/silver, pull this out for a min or so, and reinsert back on and turn your computer on, this will fully reset your bios. If you are talking about system recovery, then insert the recovery disc if provided and restart your computer, sometimes you need to set your booting priority to your cd-drive. If it has a partition recovery, it should prompt you on your dell logo bootup screen of pressing a key to do a system recovery.
Jan 23, 2011 | Computers & Internet
I ran Sony recovery CD in Dell laptop
im afraid the only way i can think of is get you hands on a dell reinstallation cd and use it. it will mean eraesing your harddrive though
Mar 25, 2009 | HP Pavilion Media Center a1330n - AMD...
I purchased a Compaq Presario (SR1810NX) in April 2006. Word software was factory installed. A few months ago, the word icon disappeared. I tried to update it on the Microsoft website and my entire...
You most likly have to format the hard drive, and completely clean out the hard drive and re-partiotion, and then install the recovery disc.
Aug 01, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
