Question about Waring DMC201 Stand Mixer
Motor housing cap
My unit tipped over and broke the top of one of the motor housings. I didn't think it would be a problem to replace so I took it off (3 screws)
My problem is I've looked high and low for a cap/top to put back on and can't find one!! I've asked 4 top waring parts suppliers and they can't find one.
I went ahead and ordered a new motor housing thinking I could get one that way and have the housing as a spare, but the housing came with NO CAP!! I called Waring direct and they are LOOKING INTO IT, but after a week no results anywhere
Where can I get a cap/top for my motor housing???
I found out from a Waring rep that the motor housing includes the upper and lower units. The company I ordered the housing from didn't include the upper unit. Waring's solution was to return the lower housings and re-order the housing unit from a better company. I haven't heard from the company I ordered it from yet although I've sent them several e-mails.
My solution was simple. I cut the lower units so they'd fit as an upper unit to replace the upper unit
Posted on Jul 23, 2008
My machine simply won't turn on .
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Remove both Brush Holder Caps (34), one on each side of the
Gearcase Motor Housing (1). The Carbon Brushes (29) are keyed
and designed to go into the Housing but only one way. Both must
make contact with the Motor Coils in order for the Motor to turn.
If they are improperly inserted or too worn out (replacement is
required) then your mixer will not run.
Jul 26, 2011 | KitchenAid KSM103 Professional 5 Series...
Did I just kill the motor on my KitchenAid Professional 350? I often use my mixer for cooking and baking, but this was the first time I'd used my pasta making attachment. I didn't even get...
If I have to guess, I think that the motor is still fine. Get a Copy of the
Repair Part List from Kitchenaid.com.
First thing I would do is to check the two Motor Brushes (one on each
side of the Motor Housing). Make sure they are not worn out, and when
inserted, they must both make contact with the Motor Coils. If even
one of them is not in contact with the coils, the motor will not run.
You can also remove the Motor Housing and visually verify that they
are touching the Coils.
Jul 23, 2011 | KitchenAid KSM50PR Professional Series...
Won't turn on
Get a copy of the Repair Part List for your model at Kitchenaid.com
On each side of the Motor Housing(1) is the large black Brush Motor
Cap(23). Each Carbon Brush(19) is keyed (one corner is not square)
and is designed to go into the Motor Housing slot but only one way.
Each Carbon Brush must make contact with the Motor Coils. The
motor will not turn if one or both does not come in contact with the coils.
If the brushes are too worn out, of course they won't touch the coils
neither and your motor will not run. You can purchased new brushes
on Ebay if they need to be replaced.
Jul 15, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
I have a KitchenAid Professional 600 Series 6-Quart Stand Mixer, model KP26M1XBS, which no longer works. I was mixing pretzel dough and the mixer stopped turning. I initially just thought it overheated...
Don't worry about the Worm Gear for now. You have to make sure that the Motor
is fully functional by itself: Remove the Transmission Housing Cover (4 screws) and
the two screws holding the Motor down. Lift the Motor off the Worm Gear and set it
on the side (be careful of AC voltages from the Motor and Control Assembly).
Select Stir setting and observe the motor shaft. Is the Motor running? If it is,
Select other speeds to see how the motor performs.
With the motor now fully functional, you can now check the Worm Gear Follower
for worn out/broken teeth. Remember the motor drives the Worm Gear, it then in
turn drives the Worm Gear Follower (you may have to remove the grease to see it)
The Bevel Gear sits right on top of the Follower and drives the Attachment Gear.
Jul 06, 2011 | KitchenAid Food Mixers
No power
There are two motor brushes, one on each side of the Motor Housing.
Both must be in contact with the motor coils. If they are too worn out
and/or improperly installed, the motor will not run. Unscrew the black
plastic caps and remove both Brush and Spring Assemblies. Notice
that the brushes are keyed (i.e. one corner is not square) and are
designed to go in the motor housing only one way, in order to make
contact with the motor coils. You can clearly see this if you have the
housing off, whether or not the brushes come in contact with the motor.
Jun 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a kitchenaid profesional 600 mixer and the attachment cap keeps falling off. Do you know how to fix this?
The Attachment Hub Cap is designed to fit tight onto the Motor Housing.
But if yours does not stay, there is a permanent solution for it.
Take a trip to Home Depot or Ace hardware and buy the J-B Industro Weld Compound
(Not the 5 minute type). Mix an equal amount from both tubes (Black and Red). Use a Q-Tip
and apply a thin layer of the mixture around the rims of the cap and install it.
Wipe off any excess epoxy.
Use a strip of duct tape to hold it in place (to prevent it from falling back out).
Allow the epoxy to dry overnight or at least for 8 hours.
The Cap is now permanently attached to the the mixer.
Jun 17, 2011 | KitchenAid Food Mixers
The problem's in a Kenwood Chef food mixer. Model is Chef A703C which I imagine will date back to the 1980's or 90's Problem # 1) The bearing on the top of motor is sloppy. It howls when operating the...
Try Ebay for parts, and the links below, they sell parts and service machines.
http://www.kenwoodchefusedmixersandspares.co.uk/
http://kenwoodchefrestore.co.uk/Service.htm
Mar 11, 2010 | Kenwood KM300 Chef Stand Mixer
Took kitchen aid apart replace old greace but it broke?
Did you remove those two screws? If so, Read my post on the one that did the same thing.
Sep 21, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
The mixing part of mixer not working motor is fine
Hi. Since I can't tell how much you have taken apart, I'll start from the beginning.
Remove the silver band, remove the top cover. At the top front of the mixer locate the transmission housing. If it's plastic, inspect it carefully for cracks around the screws and the body of this housing. If you find cracks, you have found the cheap plastic part that kitchenaid still installs in new mixers, and the cause of your trouble. They know that it's substandard but don't care enough to place a recall notice on this part. It may not please you to know that their replacement part is METAL like the original part should have been. "For the way it's made"! Indeed!
If you intend to repair the mixer yourself, go to kitchenaid's website, enter your model # and locate the parts list for your mixer. Download the drawings, they will assist you with your project.
Be sure to tell kitchenaid what you think of their cheap plastic part.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 12, 2009 | KitchenAid KP2671 Professional 6 Series...
Thumping Noise Under Duress
Hi. Your problem probably lies in the plastic transmission housing. This cheap piece of plastic has no business in a high priced mixer, as it has two important shafts that depend on the integrity of this housing for their bearing seats
Remove the top cover from the mixer. At the front top of the mixer is the trans. housing. Examine this housing carefully for cracks. If you find cracks, then you have new damage inside the mixer. If, when you replaced the three gears, I suspect that you did not discover the cracks in the trans. housing and reinstalled it after you replaced the gears, or you may have missed internal damage from the first breakdown.
When this cheap plastic part fails, it can destroy the worm gear, it's bearings and the bearing seats and possibly more.
Kitchenaid's replacement housing is made of metal. Kitchenaid markets these mixers saying it can handle bread dough. The ugly truth is they cannot!
You must open the unit up, remove and save the grease if it's relatively new. You must check every moving part in the mixer's transmission. You have to remove grease from these parts in order to find the damage. When you have the unit repaired, sell it!
I had the same problem with my mixer. I replaced all of the broken parts, and sold it. Since then, I bought a used Hobart N50 ( 5 quart), and an A200 (20 quart) mixers, both of which are commercial mixers. Both of these can handle heavy dough and they do so with ease.
Kitchenaid, to this date, have refused to recall these trans. housings, even though thousands of these cheap plastic housings have failed. Good luck with this saga!
If this solution has assisted you, please rate it. ricardok45
Mar 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Waring DMC201 Stand Mixer Logo
74 people viewed this question
Top Waring Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Waring Food Mixer Expert? Answer questions, earn points and help others
