Question about Akai PT4799HD Rear Projection Television
Akai pt4299hd Turned set on after 4 days of non-use. Convergence was way off, noticed a slight burning smell, then picture and sound went dead. Set still getting power and will turn on and off. When turning set on now the led power indicator light will blink 5 times then go out. Any idea what the issue is and cost to repair vs. buying new set.
  • Akai Master
  • 5,138 Answers
Replace your STKs big black Ics STK394-250 there is 2 of them thses are your convergence ics.Also ck resistors and pico fuses.
Posted on Dec 22, 2008
Screen distorted and burning smell
Those dead resistors that the cause,u are smelling burning plastics.Try website Tvrepairworld.com to buy a whole convergence board for the replacement.The Samsung/Akai are using the same convergence board.
Jun 06, 2010 | Akai PT4250A 42" HDTV
No picture. no sound
Bulb may have popped. Cheapest fix, unless your an electrician it the only thing to really try before replacing set.
May 31, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
I just replace convergence board on my akai tv and
There is a burnt capacitor somewhere in the unit. Look for any burnt or swelled up capacitors. You can also usually locate a bad cap if there is burn marks on the system board. Also test power supply with voltmmeter to make sure it is a constant volt reading.
Jul 11, 2009 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Sony KP-53S65 53" Rear Projection...
No Power
Ok, easy !!!.( take it out the box ) Look, in the front part of the box TV ( under convergence panel controls) you will see a little black box, we call high voltages splitter ( 5 red wires go to pictures tubes and screen focus box). Replaced it. Am suggested inspected for possible leak coolant, just for be sure noy leak coolant projection and prevent future problems. I hope this help you, Thank you !!!
Aug 03, 2008 | RCA P52926 52" Rear Projection Television
Convergence
youre convergence ICs need to be replaced there are two of them STK392-040 you can get new replacement ICs and free instructions with pictures at the following link.
http://servicemanuals.vstore.ca/
Jun 05, 2008 | Akai PT4298HD Rear Projection Television
Akai PT 4299HD picture shift
Sounds like you got it ! Note for the future....if you change
convergence amp IC's...be sure to use top quality name brand
only....no generics ! I use Panasonic with no re-calls.......T.
Feb 18, 2008 | Akai PT4298HD Rear Projection Television
Akai PT4298HD..Please help!!
Normally, yes.
Make sure you get the CG Board Part number:
BP94-00155A
There are other boards in this set that say convergence, but, they are not the boards you want.
Available at:
Andrewselectronics.com
Easy to replace.
Any questions, reply to this post and I will respond.
Jan 13, 2008 | Akai PT4298HD Rear Projection Television
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
Akai PT4799HD Rear Projection Television Logo
225 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
