Question about Casio Exilim EX-S600 Digital Camera
Battery?? my camera will not charge the battery is dead so i cannot turn the camera on but when i put it on charge the light flashes red which it should not do it should stay red then turn to green when fully charged, but also when i put it on charge i can open the photos on my camera but cannot do anything else this is still while on charge
  • Anonymous Aug 14, 2008
    same problem with the ex-880 new camera... manual says faulty battery
  • 374 Answers
Call technical support and they will replace your battery for free.
Posted on Sep 10, 2008
Kodak easyshare m320 charge light is green, but not charged
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.
Best Regards, Russell
Sep 29, 2012 | Kodak EasyShare M320 Digital Camera
Gopro charging problems flashing
GoPro battery dead. Won't charge in the camera. No charge light comes on when you connect the camera to a USB. There's the scenario. Good tip on the GoPro battery shocking technique posted by Rabscuttle above. I discovered that my vehicle USB cigarette lighter adapter drains the GoPro battery when it's turned off. With the GoPro battery completely dead, the camera will not charge it. If the GoPro battery voltage falls below a certain point, the camera's circuitry is set to turn off the internal charger as if there's no battery in the camera at all. The recommended solution is to buy an external charger, which is able to charge a completely dead battery. The battery shocking method saves that expense.
Connecting a 9 volt battery to the GoPro battery for 30 seconds can give the battery enough charge to allow the camera to recognize the battery. A 9 volt battery from a smoke detector, a pair of jumper leads, and two straight pins is what I used to get my GoPro battery charged enough to allow the camera to recognize the battery and begin charging.
battery_zps064fc8f6.jpg?t=1415296281
img_2564_zpse9e14b4e.jpg?t=1415296297
May 30, 2012 | GoPro Cameras
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Casio Exilim battery won't charge
What model of camera? You will probably need to purchase different battery.
Mar 18, 2008 | Casio Exilim EX-Z40 Digital Camera
Battery wearing down when in camera
First do not leave the battery in your cam, it will affect the cam. Use prescribed battery. Charge the battery for at least 8hrs.
Jan 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Troubleshooting.
Blinking light means charging error. Call tech support and they will replace battery for you for free.
Nov 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
New Camera Does Not Charge
A red flashing light does NOT mean it charging. THat means you have a defective battery. Call tech support and tell them that you have a defective battery and they may be able to get a replacement for you.
Jun 08, 2007 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
