Question about Dryers
Dryer model LSE9900
I have maytag dryer model LSE9900, it's working but it doesn't generate heat, the closes still wet
Thank you
    Genius:
  • 1,122 Answers
FIRST THING TO CHECK IS THE DRYER VENT HOSE ,MAKE SURE IT'S CLEAR,THEN THE VENT WALL HOLE,STICK YOUR HAND UP IN THERE AND PULL ANY LENT OUT THEN GET A SHOP VAC PULL IT IN THERE WITH A RAG AROUND IT TO MAKE A TIGHT SEAL AND **** IT OUT,IF THIS DOENT DO IT YOUR HEATER BOX IS BAD,CALL A APPLIANCE REPAIR PERSON(NOT SEARS$105 JUST TO COME OUT)THANKS-MIKE
Posted on Jul 22, 2008
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag dryer MDG7600AWW doesn't dry at all anymore.
heatman101
Aug 25, 2011 | Maytag MDG7600AW Gas Dryer
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
My Maytag dryer Model MDG5500AW is running but the inside is cool and does not heat up. I tried both Sensor Dry and Time Dry, it still cannot het up. What could go wrong? And what do you suggest that i...
heatman101
May 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Hi i have a ge gas dryer model # dclr333gtoww serial # fr301056g 22,000 btu im not getting any heat it tumbles i checked the plug and the breaker thats all fine i have not checked the thermal fuse or the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Dryers
Dryer heats up but close remain wet
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Gas dryer won't ignite. ignitor pulls 3.8amps. thermal fuse has continuity. flame sensor is working. jumped sensor no resultbesides checking outgas valve coil for ohms what other possibilities could...
heatman101
Aug 31, 2010 | Maytag Dryers
Maytag gas dryer wont heat
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
Mar 28, 2009 | Maytag MDG2706A Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Electric maytag stack dryer not heating...
That dryer is made by Speed Queen. A common failure part is the thermal overload, mounted on the heater box. Items 4 and 6 in the picture Iposted are possiblities.
Dec 14, 2008 | Maytag SDE2606 Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
